Trailing arms question
Old Jun 11, 2011 | 07:05 PM
BuffaloBILL's Avatar
BuffaloBILL
Default Trailing arms question
Hello Gang
A friend of mine had a tree fall on his 78 Vett willing to sell his complete rear suspension Trailing arms spindles rear end Will the trailing arms and spindles work on a C2 or are the specs different
Excuse my ignorance
BuffaloBILL
Old Jun 11, 2011 | 07:15 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
I believe they are the same. Places like Corvette Central, etc. list them as 65-82 with the same part numbers.
Old Jun 11, 2011 | 07:27 PM
vt65's Avatar
vt65
yes the same, just bought a complete rear and front suspension for my '65 out of a '75 in good shape for $500., the diff is also the same, the diff. is all i needed but nice to have the spare parts ... Don't forget to grab the Power Steering parts also if you can, if you don't already have it, for when you old and feeble like me ...
Old Jun 12, 2011 | 11:36 AM
ditchdigger650's Avatar
ditchdigger650
I know I put a 75 crossmember in mine, if that helps.
Old Jun 13, 2011 | 12:03 PM
Vtechcorvette's Avatar
Vtechcorvette
Yes They most certainly will!
Old Jun 17, 2011 | 05:19 PM
remotecontroller's Avatar
remotecontroller
Keep in mind difference in C2 drum vs disk brake setups - the spindles, etc. are different. Pretty sure ok if C2 Disk brake car you are doing the swap in.
To Trailing arms question
