Ls3-c2
BTW, I had the gauges converted by Redline Gauge Works to electronic. Boy did they do a nice job!!
Yes, I will have the car hauled to the right person.
Have you considered a nice 383? You can get 400HP if you need 400hp, It WILL Bolt in.
I would guess that LS conversions are 15-20K deals, by the time you are finished and add it all up.
Unless you car is really far gone from stock you may want to re-consider.
I mean, the LS cars are really neat, I like them and admire the craftmanship, and if your doing it to show off your skills well that is something different.....but.......It would be tough for me to commit to that program for a small marginal gain.
I've had 3 quotes from CA and AR and all the price quotes jive.
If you're going with LS3,4L70E, and everythng is new, the cost for just the parts is 18K. If you add A/C, tilt steering, and orig. gauges upgraded, add another $2,800. And that's w/o new, wider wheels, or suspension upgrades.
The only thing left is labor...
I'm now looking into a used LS2/tranny...plus, alot of the parts and harness are already included.
Now if you had a truck motor, then that changes a bit. The intake will have to go, the FEAD needs to be swapped, oil pan...well that's about it.
The position I was in was I had a bone stock '64 that needed about everthing except for interior work and paint. The chassis needed to be rebuilt, radiator couldn't do it's job, brakes were awful, and I hated the wheels and tires. So I could rebuild the whole deal as per stock, or I could stuff in a LS since I was replacing all the key conversion items anyway (transmission, radiator, exhaust, and wiring). So it was a natural for me. BUT, if I were paying somebody else to do it, I'd just use a well-built small block with injection. I probably will have 300 hours into this when I'm done (which includes stripping the frame and powdercoating everything, replacing all wear items, etc), and at a normal shop rate, that's about $20k in labor. I'd pass on that...
I like engine swaps, I get a sense of accomplishment from making things. I have done three swaps in the past, MG-mazda, Jaguar-chev, Sports racing car ford to mazda.
But.............building a car takes alot more time than fixing one!
Thats why I think a 383 with good aluminum heads is the hot set up. Now with that nifty FAST fuelie deal and a 5 speed, then you would reall have something!
My radiator is a bolt-in too with off the shelf hoses.
But if a guy just wants something to bolt-on and go, then obviously a LS isn't the way to go. But in my opinion, the advantages of a LS engine far outweigh the downside of the extra work (which is easy for me to say, since I'm vary familiar with doing these swaps).
Based on list above, would add fuel delivery to your list of additional expenses.
