Oil Recommendations
Old Jun 16, 2011 | 12:37 PM
1KULC7's Avatar
1KULC7
Veteran: Coast Guard
Default Oil Recommendations
Got to change the oil in the 63 L-76 (340 HP). I still use the canister with filter. I have been using Quaker State, and was told to stay away from the Synetic Oils as they are too thin and will leak. I understand that I should get oil with ZDDP. and it should be 10-40. I have totally stock 63 L-76 340HP engine... Suggestions?
Old Jun 16, 2011 | 12:47 PM
5thvet's Avatar
5thvet
I Shell Rotella D Multigrade 15W-40. It has a zinc content of about 1200
Here is a good thread on oils.
http://forums.corvetteforum.com/c1-a...ppet-oils.html
Old Jun 16, 2011 | 01:37 PM
Bill Lacy's Avatar
Bill Lacy
thats what I use in my 67/435
Old Jun 16, 2011 | 01:40 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
any 15W40 DIESEL oil, even WallyWorld has a good store brand.
Bill
Old Jun 16, 2011 | 03:02 PM
427435's Avatar
427435
[QUOTE=EBVette; and was told to stay away from the Synetic Oils as they are too thin and will leak. [/QUOTE]
Old Wives tale. I've been using Mobil 1 15w-50 in my 427/435 but it doesn't see much use due to worn out suspension. I plan on going to their Turbo Diesel oil which is what I've started using in everything else I have (lawn mowers to motorhome).
Here's a link to what's in the various Mobil 1 oils. There are other good oils, but I always liked that you could easily get tech info on Mobil 1 oils.
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
Old Jun 16, 2011 | 09:34 PM
vt65's Avatar
vt65
you heard right, synthetic oil does have a smaller molecular structure than conventional oil, that's why it has superior lubrication qualities, that is also why it tends to leak out of older engines more readily.
Old Jun 16, 2011 | 09:55 PM
bojangles's Avatar
bojangles
I use Brad Penn...the 'green stuff'
Old Jun 16, 2011 | 11:00 PM
StingU2's Avatar
StingU2
... the only oil I have used in my '64 L76
Old Jun 16, 2011 | 11:20 PM
427435's Avatar
427435
Sounds like pseudo-science to me. If the molecules are smaller, the viscosity would be lower--------thus not meeting whatever API viscosity the oil is being sold as.
Old Jun 17, 2011 | 08:04 AM
1KULC7's Avatar
1KULC7
Thank you all for your help, it appears I will be changing oil this week end. Don't you just love the old canisters....Thanks
Old Jun 17, 2011 | 09:27 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
After 40 years I'm getting real good at seating that gasket
I use Shell Rotella 15W 40 in all my old cars. I like Wix Filters.
Old Jun 17, 2011 | 12:59 PM
65 vette dude's Avatar
65 vette dude
It's high in zddp, and it's partial synthetic.....terrific stuff.
Old Jun 17, 2011 | 01:16 PM
sub006's Avatar
sub006
Back in the day, the Ferrari owners' manual specified only one oil, Shell Rotella STRAIGHT 40-weight! Had to visit the truck stop to buy a case (12-quart sump).
Old Jun 17, 2011 | 01:21 PM
92GTA's Avatar
92GTA
Synthetic or not really depends on the gasket material which was used on the current build, no more.
I use Redline, it already has the ZDDP needed.
Old Jun 18, 2011 | 11:11 AM
gwalker's Avatar
gwalker
Synthetics are a superior oil. This is why I have just changed to Mobil 1 15-40. My 63 has that very small drip, that I think all very old cars that are driven seem to have. I have seen no difference from switching this year. I guess worse case, if it does start leaking, I will just switch back.
Greg
Old Jun 18, 2011 | 09:15 PM
Oz's 59's Avatar
Oz's 59
Greg
I use the Mobil-1 in my '59 w/ no leaks. *But Note: only the 15w-50 has the ZDDP needed!
“Nominal Zinc Level (PPM) = 1300 Boosted, higher viscosity, fully synthetic formula designed for performance vehicles. HT/HS applications. Racing and Flat tappet applications.”
The ZDDP in the Shell Rotella has been reduce and is no longer "good enought".
Old Jun 18, 2011 | 11:30 PM
427435's Avatar
427435
Originally Posted by Oz's 59
I've been use the Mobil-1 in my '59 w/ no leaks.
*But Note: only the 15w-40 has the ZDDP needed!
Mobil 1 doesn't come in a 15w-40. It does come in a 15w-50. Their 5w-40 diesel oil also has plenty of ZDDP and gives better start-up lubrication.
Again, here's a link to what's in the various Mobil 1 oils: http://www.mobiloil.com/USA-English/...duct_Guide.pdf
To Oil Recommendations
Old Jun 19, 2011 | 12:06 AM
Gumpy's Avatar
Gumpy
I use 40wt valvoline racing oil with lucas zinc additive for top end lubrication...just trying it out....came recommended
Old Jun 19, 2011 | 04:16 PM
gwalker's Avatar
gwalker
[QUOTE=427435;1577916054]Mobil 1 doesn't come in a 15w-40. It does come in a 15w-50. Their 5w-40 diesel oil also has plenty of ZDDP and gives better start-up lubrication.
My bad, I put in Mobil 1, 5 - 30.
Greg
Old Jun 19, 2011 | 04:44 PM
JohnZ's Avatar
JohnZ
Wrong. CJ-4-rated Rotella has 1100-1200 ppm zinc/phos and is more than adequate for any OEM valvetrain. Different story if you have an aftermarket cam and Gonzo valve springs.
