Converting '65 Rubber Fuel Line to Hard Line..Filter to Carb
Seems like GM used rubber on the engines with aluminum intake manifold as the 300hp engines used steel all the way. I am not sure if the rubber line insulated the fuel from heat off the aluminum intake, the factory fuel pump pressure is well below any pressure rating on the rubber so no need to worry there.
Never use compression fittings on a fuel line.
In 1966 all the lines were steel to the carburetor but keep in mind the engines shared the same carburetor so using the same line and carburetor saved $$$ and that may be all that there was to it.
Rubber lines over a hot intake are problematic.
Many use screw clamps and over tighten them causing seepage from damaged lines and the rubber deteriorates quickly during the rounds of baking heat and cooling down and vibration - not so much a matter of 5-1/2 lbs fuel pressure as aging. How many old cars have we all seen where the vacuum hoses were brittle and cracked ? Unlike the C1s, the base motor C2 carb inlets are hard to see under those massive air cleaners and so inspecting the lines regularly may take more effort than many care to do.
I wouldn't use them.
Received 1,843 Likes
I would be 100 times more concerned about a needle/seat hanging open in a carb and flooding the top of the engine than I would a rubber fuel hose leaking as long as the hose wasn't twenty years old.
But I don't worry about the needle/seat deal (even though I've had it happen) so I don't worry about the rubber fuel hose(s).
PS
"My car has power steering so the alternator is mounted on the right side". New one on me!
PS
PS
PS
I changed my carb to a double pumper, and didn't want any ugly rubber lines. I would be fine with short rubber line to factory carb. My factory 2818 always seemed to have a leak, so I have it off for now. My car also was not a PS car from factory. When I bought the kit, the instructions said to move alternator to right side, so I followed them and did so. It is a facotry style PS set up though.
I can't explain that one, except maybe because there is a lubricant in antifreeze? I know modern fuels with ethanol eat up rubber lines too. May even eat up steel lines over time. Parts store tried to sell me some green metal lines when I built my fuel line the other day. They said it was better with ethanol gas, but I didn't want the ugly things. I always keep an eye on everything in my car all the time. I just don't like ugly rubber lines with clamps everywhere.
Chris
alternator
Another reason I mentioned the alternator, is the picture in this thread shows alternator on left side. Guess his is on wrong side then, or he removed his A/C? He shows how to make fuel line, and I had troubles due to alternator in the way. So, go back and look at that MikeM, since you seem to be negative Nancy in all these threads...
It appears to be... I am pretty knowledgeable about corvettes, but I honestly don't know which side the alternator is supposed to be on from year to year. My car was supposed to get vintage A/C added to it at one time, so maybe they moved alternator for that? When I bought PS kit, guy asked if it was A/C car, which it wasn't. The pulley configuration required alternator on right side, so I moved it. I have other cars, so hard to know all about each one. This forum is very informative and almost everyone is nice. That MikeM guy is negative in almost every comment throughout this thing. If you don't want to help, go bother someone else is my point. I am a Police Detective, I deal with negative all day. I have cars to try to take me away from that...
#33
I have room for one more of your nasty PM's and then my PM box will be full.
#34
I hope you were more helpful at your FOMOCO manufacturing job then you are on this forum too!
#35
Could you recommend a good doughnut shop in Huntsville? I go through there a couple times a year. Maybe I could stop and you could buy me a cup of coffee and a doughnut. With yer cop discount, won't cost you too much and we could chat about the pressures of your job and how to handle it a little better without lashing out at members of this forum.
PS. Long, long time ago, I wanted to be a State Trooper. Or a municipal cop. Then I thought, nah................... All you see is the bad side of people, never the good. Time to move on.
#36
Yes, I was very well compensated for being helpful there. Thanks!
PS: like i said keep rude smart butt comments to yourself.. then someone will see good in you!
#37
PS. You sound overly aggressive like many of the rest of them and I think you may be borderline in violation of forum rules. Please try to control yourself before you get in trouble here!
#38
Dont eat doughnuts... if you saw me you would know that. Now go get a mustang with your FOMOCO discount. Then take computer ***** with you to mustang forum with rest of ignorant people.
#39
Received 1,857 Likes
#40
From '63-'65, all small-block alternators were on the passenger side (except with A/C, which moved them to the driver's side). '65 L-78 BB's had them on the driver's side. From '66-'67, ALL alternators (including BB's and A/C cars) were on the driver's side. Power steering has no effect on the location of the alternator on any engine.
