coolant additive help
Old Jul 7, 2011 | 09:46 AM
Tom Schaefer's Avatar
Tom Schaefer
Default coolant additive help
I want my 427 to run cooler,I heard water wetter is good any other recomendations? thanks Tom
Old Jul 7, 2011 | 09:55 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Tom, It would be helpful if you told us more. Engine configuration/mods-vs-stock. What is the gauge reading, versus an actual reading via a heat gun at various points. Does this happen at speed or idle. Many of things will help us. Overall I think these additives fall in the catagory of snake oil, but I'm not passing judgement. Tell us more. Dennis
Old Jul 7, 2011 | 10:02 AM
Tom Schaefer
I didnt take a actual reading ,but my carb perculates, I want to stop that,its a 427 390 stock motor. thanks Tom
Old Jul 7, 2011 | 10:14 AM
Bluestripe67
You really need too establish the actual operating temp and go from there. Sometimes a phanolic resin insulator between the carb and manifold can help, but it may cause air breather interference with the hood. Dennis
Old Jul 7, 2011 | 10:22 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
No - you need to get an I/R temperature gun and shoot the carb bowls to see what the temperature is there. You can have a perfectly cool-running car as far as water temperature goes and still get fuel percolation...the two items are not always related.
Old Jul 7, 2011 | 10:58 AM
Tom Schaefer
this is all great info,thanks Tom
Old Jul 7, 2011 | 11:13 AM
Mike Ward's Avatar
Mike Ward
I believe the 'magic ingredients' in water wetter are a standard part of the additive package in all coolants.
Old Jul 7, 2011 | 12:07 PM
PaulUptime's Avatar
PaulUptime
I agree on Water Wetter not being all that effective. I just did a complete engine and rad flush and replaced all my coolant and decided not to use WW again. If it does anything, I can say from my past experience it doesn't do much.
Old Jul 7, 2011 | 02:00 PM
midyearvette's Avatar
midyearvette
snake oil...jmo....
Old Jul 7, 2011 | 02:03 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
I used it in another car and it did help a little. I saw a 5º to 7º drop in temps., which is not much, but it did do something.
Old Jul 7, 2011 | 03:54 PM
John S 1961's Avatar
John S 1961
some racing groups specify water wetter exclusively, because spilled glycol coolant is so slippery and doesnt clean up easily.
220 degrees is ok, 230 is too hot. Our old vettes are undercooled compared to new cars you may be used to these days, but out new cars still have 190-200 degree thermostats.
You may need to fork out for a very good radiator.
Old Jul 7, 2011 | 07:02 PM
wombvette's Avatar
wombvette
Originally Posted by midyearvette
snake oil...jmo....
Funny, they are trying to sell you something that makes WATER WETTER.
Old Jul 7, 2011 | 07:07 PM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
Has your radiator ever been gone been cleaned? I suspect that most of these 40 yr.old radiators are running at an efficiency rate of 70%. Cheapest fix is a DeWitt. Troubles are gone.
Old Jul 7, 2011 | 07:17 PM
street62's Avatar
street62
Since this should be a summer car only. I block the eggaust crossover between the intake and the heads with some thin stainless steel. This will cool down the carb. I have found if you run less coolant and more water , say only good for 0 degrees, then go back to 50/50for the winter, it transfers the heat better . It breaks the surface tension. I have been battling heat for 38 years.
Old Jul 7, 2011 | 08:04 PM
mikem350's Avatar
mikem350
Along these lines..make sure the heat riser on the exhaust is OPEN...(I would wire it just to make sure it STAYS open)
Old Jul 7, 2011 | 08:27 PM
tach drive 61's Avatar
tach drive 61
I agree block the crossover under carbs/ I run mt 2x4 setup that way now .no heat riser at all eliminated with a block , and less anti freeze helps as well .another thing buy good gas if possible .also do have a electric fan but never need to use it .knock on wood !
Old Jul 7, 2011 | 08:36 PM
1snake's Avatar
1snake
Water Wetter is nothing more than a "surfactant". If you are using plain water, it will help. If you are using a combination of anti-freeze and water, you're wasting your money. Anti-freeze already has it in it.
Jim
To coolant additive help
Old Jul 8, 2011 | 05:06 PM
JohnZ's Avatar
JohnZ
Take a look at this to understand how your Corvette cooling system really works:
http://www.lbfun.com/warehouse/tech_...em/cooling.pdf
As noted in the last sentence, solutions to cooling problems come in boxes, not in bottles.
Old Jul 8, 2011 | 05:50 PM
92GTA's Avatar
92GTA
The only cooling system fluid trick that works is totally flushing and replacing the water and anti-freeze/coolant with a synthetic replacement fuild. Motorcycle racers and auto racers go this route.
Old Jul 8, 2011 | 06:37 PM
66since71's Avatar
66since71
The additive packages in antifreeze do lose their effectiveness and should probably be replaced ever couple of years (the additive package, that includes surfactants and corrosion inhibitors). The antifreeze itself never wears out. I was involved in some OEM research on this one. You'll find the same conclusion in johnZ's article above. We just differ on the need to replace the entire coolant load...
Harry
