67 window play (help)
Old Jul 11, 2011 | 12:17 PM
gtjr's Avatar
gtjr
Default 67 window play (help)
1967 convertible 327-300hp-4spd. driver side window has a lot of side to side play. Itook door panel off , only thing i could see was the window felt run was worn out. What is the fix Iam sure other owners have this same thing . THANKS GEORGE
Old Jul 11, 2011 | 12:29 PM
Blk63Vette's Avatar
Blk63Vette
Felt and probably outside window trim, and also look at the window channel "grip" stuff dry rots.., also felt for vent window...You replace that it will be tighter...I just replaced all this stuff on both my doors..
Old Jul 11, 2011 | 08:18 PM
Reeltales's Avatar
Reeltales
I agree with BLK63Vette. I had a lot of side playon my passenger window. I replace the rear run felt and installed a new felt track on the vent window. I originally thought that there must be more wrong with the window in order to have as much play as it had. However, the new weather stripping corrected the problem.
To 67 window play (help)
