I'm getting ready to pull the engine (L79) and transmission (muncie) as a unit. I have a "tilter" that should make the job a little easier. I've removed the radiator and shroud, but still have a few questions:
1. Do I need to drain the oil?
2. Do I need to take the water pump off?
3. Do I need to take off the crankshaft pulley?
I'd like to do as little as possible so things go back together as quickly as possible. Thanks for the help!
I removed my L76 with all the stuff still in place. I removed the carb only. The only issue I ran into was the engine crane's reach. The center of the engine is pretty far back from the nose. Make sure the hydraulic cylinder on your engine crane doesn't lean against the car's nose.
I used a tilter also. I needed to adjust it as the engine came out. It will be at a pretty steep angle and you need to get the engine/trans combination pretty high. Make sure you don't have the engine crane too close to the intake manifold. When you tilt the engine, the crane may contact the front of the engine if the chains are too short.
From: Livin' large and havin' fun in wonderful Oklahoma
Tom
Tom,
I always have pulled the fuel pump...two bolts, 10 minutes and it's out. You may ask why? The pump is next to the right upper a-arm. When you start picking the engine up, moving it forward more times than not the pump will contact the a-arm. By pulling the pump you get 3 to 4 inches of wiggle room to pull up and out. Just a thought.
The only thing I remove is the distributor, fan and clutch. Removing engine with a helper, those other items do not need pulling. I put mine back in the same way. Assembled!
Seems the newer cranes have short arms, kinda made for FWD cars. If you have an old school or more heavy duty crane it should be ok.
My son's cheapie "Big Red" Pep Boy crane made me have to pull and install his BB side saddle
Going in from the side is going to be tough with the trans attached unless your lift rolls easy side-to-side. If car is facing front of garage having the door open should leave plenty of room.
The plan is to take it out the passenger side. . . may not have enough room in the garage to pull it from the front! May be a little trickier!
I've never heard of anyone doing it from the side. I would push the car outside and do it from the front. I would also drain the transmission oil. When the motor/trans is tilted up and the driveshaft is out the trans oil can come out of the rear of the trans.
My cherry picker boom reach came up about 10 inches short to do an engine pull from the front. Had to come in from the side. A little inconvenient but not too bad.
