Dyno Tune
you can find 100 horses on the dyno if the baseline is terrible, the sky is the limit, if your car is real close, he might find 10, but really that would be nominal because he wold be tuning for that peticular day's air density, humitity, and tempature
as soon as the sun rises tomorrow, the world is a different place.
But, you'd at least find out the condition of your tune, and you'd likely leave there with the tune optimized to the point that you'd know you didn't need to mess with timing and jets anymore.
Dave
This takes more time, and as we know time=money
They jetted the carb for the altitude change and set timing to maximize power, torque, and air/fuel mixture. Gave me several nice graphs, so I have a good baseline for future adjustments. Dyno time ran me about $220/hr, so make sure easy stuff (new plugs, good spark plug wires, etc) is done in advance, so they can focus on adjustments and get you off the Dyno as soon as possible.
The 327/350 has the laziest centrifugal advance map of all the 1965 smallblocks. For best results, start with slightly rich jetting to stave off detonation, and aim for the fastest advance that the engine can handle. If your engine is a stock build using the 151 cam, then if it will tolerate 16 degrees initial and another 20 centrifugal, all in by about 3000, then you will have an excellent performer. This will mean doing some modifications to the advance slot in the distributor's advance mechanism. Remove and do not use the advance slot bushing, and weld up the slot so as to limit max centrifugal to 20 degrees. Mix and match springs to bring in advance as quickly as possible without detonation. It is perfectly acceptable to use 2 different springs on the 2 flyweights.
Once the spark advance, both vacuum and mechanical are set, then decrease jet size until onset of detonation at tip in during cruising...........this is the point of max spark advance and also near max cylinder pressure if the cruise RPM is around 3500 RPM. Step up one jet size from this point. Remember to be consistent with your gasoline. I use Sunoco Ultra 93 since it's the highest octane available in my area, and priced equally with competitors' Tier One gasolines.
As a final check, you can get the car to cruise speed and keep it there for at least 15 minutes. Shut it off while at speed and pull over to a safe spot. Remove and record the color of all 8 plugs. On a 2 plane manifold, the high half of the plenum (passenger side) feeds cylinders 2-3-5-8 and is normally richer than the opposite side. The lower half (driver's side) feeds 1-4-6-7 and is usually leaner than the opposite half. If the spark plugs agree with this, then you can stagger jet the carburetor by one jet size. Of course, you should also compensate with the idle mixture screws to balance them accordingly, as well.
Obviously, all of this takes a lot of time. At $220.00 an hour dyno time, it is not feasible to do this kind of thorough tuning. Computer controlled powertrains are a completely different animal, and dyno tuning for them is a very valuable tool. For pre emissions controlled engines, dyno tuning is not economically feasible unless you own the dyno.
But the last dyno run, after Lars tuned the car, was at 12.9:1 A/F ratio and I don't think he can get 30 hp by changing the A/F ratio a couple tenths of a point one way or the other.
Depends on what you drive in with.
Questions:
1. Can you tell me the part number of your pistons? If they are the most common replacements for the weaker engines, then they are plain cast aluminum, have 4 valve reliefs and the dome volume is -5.3cc as opposed to the L2166NF forged domed aluminum whose volumes are +5.3cc. There are also 2 valve relief hypereutectics from Speed Pro whose dome volume is -5.0cc.
2. Were the decks or heads ever milled, to your knowledge?
3. What is the overbore, if known?
4. What is the head gasket used on your build. Need compressed thickness and bore diameter.
These will give us an accurate starting point for the engine's static compression ratio. I assume that your heads are 2.02/1.60 461's; if they have not been surface ground then their combustion chamber volume is 66cc. The "small valve" 461's are 64cc. The 62cc heads will gain you some more much needed static compression, but not enough to make the head swap worth the effort..................unless.......... ............you have anything other than steel shim head gaskets in place now. I normally would NOT recommend them, but in your case, the better sealing MLS or composite gaskets are .036", minimum and you need ALL THE static compression you can get.
Because of the SCR deficit, I recommend advancing the cam timing by 4 additional degrees beyond the stock 4 degree recommendation, for a total of eight degrees. Of course, there are better ways to build SCR, the best way by far would be to ACCURATELY deck the block to zero or probably negative deck clearance. Doing this will give you the required 10.75 - 11.0 SCR and, equally important, square up those woefully lopsided decks that were hewn with that monstrous contraption known as a broaching machine. The inaccuracy of that Rube Goldberg device is in the neighborhood of .030", which can leave the nominal deck height of your block at 9.025" plus/minus .020"/.010".
Assuming a .030 overbore, a .019" steel shim head gasket whose bore is 4.100, and 9.025 decks with 4 eyebrow flattops (-5.3cc), 3.25 stroke, 2.02/1.60 461's, and virgin decks and head surfaces.....................your calculated SCR is 9.42:1..............1.25 points below the minimum ideal required for a 151 cam whose timing is 4 degrees advanced.
Having said all of this, I can safely say that if you do nothing to fix your engine's SCR deficit, then you should set your initial timing to 20 degrees, set the stop on the mechanical advance to 18 degrees, use the lightest advance springs possible so as to have your advance come all-in by 2300, and have your vacuum advance function as original and delivering a full 16.5 degrees crankshaft advance at 8.2 in-hg, as original when connected to full manifold vacuum. Any more spark advance than this (even though the engine will still not experience detonation because of your pathetically low cylinder pressure) will kill torque and power.
If you do these things, then try to run the car on mid grade, or even regular fuel. There is a better than even chance that it will run detonation free on regular, and almost a certainty to run detonation free on mid grade.
I know, I have regretted not installing domed pistons almost since the motor was rebuilt.
-The bore is .030 over
-Don't know what piston but I don't think is is a hyper
-the deck was milled I think .010
-I am pretty sure the heads were also milled as I had them completely reworked
-I think the head gaskets are Fel Pro. not sure of the p/n
Thanks for your input. I appreciate it.
Jet the carb the way I recommended earlier and save your money on the "tune" session. Fill the tank with regular gas and enjoy your Corvette. Curious about power output on the finished product? Pay the usual $100.00 for three pulls and run one in 4th gear and the other two in third gear. Make sure that the pulls start out at 2000-2500 RPM, air cleaner base installed, cover and filter removed, hood open, brand new spark plugs.
Of course, you can always shave those new heads and bring your chambers down to 58cc. If you decide to do that, then we'll have to rework the timing and upgrade to premium fuel.
