1960 Corvette Engine Serial Number Stamping Question
Hoping you can help a fellow CF member. Regarding a 1960 Corvette with a late production run July VIN, is it possible to only have the Engine ID (in my case: F0724CT) stamped on the front engine pad without the Engine Serial Number stamped in front of it?
It is my understanding for the 1960 model year, the Engine Serial Number is stamped to the left immediately followed by the Engine ID to the right. Is this the case? If so, why does this car only have the Engine ID stamped and not the Engine Serial Number?
Perhaps was mine a re-stamp performed incorrectly? Or could a July VIN only have an Engine ID?
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
Not "for" the 1960 model year... "during" the 1960 model year.
VIN derivatives started to appear on 1960 Corvette engines around mid-December '59, approximately at VIN 1800.
Different size characters also changed during the rest of the run.
EDIT Jim you beat me while I was typing!
If the motor only has the Engine ID (F0724CT) stamped on the pad and not the Serial Number, could this have been done as a factory/dealer Counter Exchange process?
I just find it ironic that someone would re-stamp the motor with only the Engine ID re-stamped? Why go through the process and not perform correctly?
Early 60 VIN stamps also look like they were stamped by a drunken sailor, as the attached pic of my 60 shows. Clearly, they had not started using gang holders yet!
http://img.villagephotos.com/p/2003-...3/P0000170.jpg
Regards, John McGraw
Jim
Jim
have a question
I bought a pickup awhile back and when i pulled the motor i had my grandpa look it up beacause there are no vin numbers just the casting number my grandpa used to work for gm and told me he has heard of these and he thought there was a market i was wanting to know if there is a market and were would i go i beleive he told me it was an early 59 283 and thats about all i know i had it running one day sounds like it is cammed slightly but thats about all the farther i messed with it and is it considerd a numbers matching car if one of these motors with these casting numbers is in a 58 or 49 vette
Received 1,857 Likes
Might be one of those really rare 49's with a "W"-block; some were built for the World's Fair, and haven't been seen since; let us know how it turns out.
Received 6,529 Likes
C2 of Year Finalist (track prepared) 2019
I apologize on my typo i ment 58 or 59 not 49 im pretty aure its either of those but ill have to go to my grandparents and look it back up
I know this thread is over two years old, and John had me going there for a few seconds, but......
Jim, unless I missed something else that you noticed.....
It appears to me to be a '60 engine stamp. In '60 they didn't prefix the vin derivative with the year, correct? The "1" in "10xxxx" is not the year. In '61 the single digit year was added as the prefix to the derivative. eg 110xxxx"
Rich
Rich
10,261 vetes were produced that year
Rich
Rich
Thanks,
Jim
Nope, Original engine, one owner car (until I bought it). Car was built 5/24/60, engine stamped 5/19/60. Owner purchased car from Sonny Stein Chev in Philadelphia in late Jun of 60. Have all documents and service records. The only thing the owner did was change from a 3 speed to a 4 speed in 1961.
Tom
Tom
The model year prefix digit on the stamp pad VIN derivative didn't start until the 1961 model year.
