Had an interesting idea but don't know how lucrative it would be. (Maybe applicable for drag racing as it may not violate any rules).
How about blocking off the heat riser on the intake manifold and running cold water though this space under the carb? There may not be enough surface area to be worth it, but in some applications, every little bit can help.
And it certainly couldn't hurt with fuel percolation and vapor lock problems.
Why not just go with a cool can for the fuel lines?
and a phenolic spacer.
The biggest HP and drivability impprovement would be to add a cool (outside)air induction system.
I thought it would cool for holley to make refrigerated fuel bowls for a/c cars. Even better a freon cooled gas filter. Just tap into the a/c freon system.
You see a few guys in the staging lanes with a bag of ice on each side of their intake. The turbo Buicks really run well with the intake cooled down.
Yes, and I would always ice the plenum on my C4.
I recognize there are spacers (I use one now) and cold cans, but there is no saying that you can't have it all.
Some time ago one guy on the C3 forum (IIRC) shot an infra-red heat gun at the intake/carb and the spot under the carb was the hottest point on the engine (though I'm sure that the crossover was open).
With all the restrictions in "stock" classes, this seems like something that may have slipped through the loop holes in drag racing.
Ahh, sounds like something with more stealth would be desired.
If blocked off the ports and filled the heat crossover under the carb with water, I think it would quickly heat up and become as bad as hot antifreeze circulating under the carb.
If stealth is not a concern, I know some on the C6 forum are plumbing their A/C lines into a system to help their supercharger intercoolers and thus something like that with tubes going to the intake would probably help, but not sure how much given - as you say - the limited surface area.
Sounds interesting if you wanted to wring every bit of power. You could plumb something like a tranny cooler and a pump and combine it with a cold air intake.
How about just installing the right manifold?
Victor Jr. on my 66. Nothing but air under there.
Imagine if you enclosed those runners in sheet aluminum then pumped chilled water though it so that it circulated all round those runners. Gotta be more efficient than hot air.
Plus, water removes heat 7 times faster than air does.
I would be adding needless weight and additional equipment failure points for minimal horsepower improvement. Feed cool air to the carb intake, avoid adding heat via runners, then you don't need to cool it down.
Nice looking engine. But the way you have the return spring set up is the worst way to do it. That set up will wear the throttle shaft and throttle bore. It always has pressure on the shaft and bore.
