New engine-storage-need advice.
Old Jul 24, 2011 | 11:28 AM
Steve59's Avatar
Steve59
Default New engine-storage-need advice.
I had a matching numbers engine built with parts that I've located over the last few years. It's complete from fan to flywheel and carb to pan. It's now sitting in my garage on a cradle and it looks as if it may be there for awhile. My questions are:
1. Is there some way that I can turn it over (other than by hand) now and then and get oil up into the heads? It's on a cradle so attaching the bell housing and using a starter is out. I just want to spin it to keep everything lubed.
2. Before I actually install it, I would like to run it, to make sure all is good. How would I go about that?
Steve
Old Jul 24, 2011 | 11:37 AM
6T5RUSH's Avatar
6T5RUSH
Cruise-In III Veteran
steve59,
Not cheap, but this is the ideal if money is no object:
http://www.easy-run.net/
And, here's a youtube video of a do it yourself setup:
http://www.youtube.com/watch?v=Ek-aR...eature=related
Good luck!
Jim
In God We Trust!
Old Jul 24, 2011 | 11:55 AM
62Jeff's Avatar
62Jeff
If it's going to sit there for year(s) I'd pull the valve covers, pour Rislone oil additive over everything, loosen the rocker arms to allow all 16 valves to close, put the valve covers back on it, and leave it alone. Then I'd pull the spark plugs and spray some WD-40 into the cylinders to help prevent surface rust and put the plugs back in and you are done.
I think anything you do to provide some sort of automated oiling system (like a drill-powered oiler down the distributor hole) would eventually wash the assembly lube off the cam and other parts, creating a risk of damage when you go to start the engine.
Old Jul 24, 2011 | 12:08 PM
MikeM's Avatar
MikeM
If it were mine, I'd oil up the top end and put the valve covers back on. You could even back off the rocker arms to take tension off the springs. Tape the exhaust/intake shut with duct tape to keep moisture, rodents and insects out and forget about it.
I built an engine run-in stand for about $50 total. All you need for starters is a roll around engine cradle, some square tube, radiator, switch, couple of gauges, couple hours time and you're in business.
Old Jul 25, 2011 | 04:23 PM
Steve59's Avatar
Steve59
thanks gentlemen, I appreciate the info and advice.
To New engine-storage-need advice.
