chrome manifold
Old Jul 27, 2011 | 11:48 PM
corvettecsn's Avatar
corvettecsn
Default chrome manifold
I found a edelbrock Torker manifold in great shape I would like to use but it is the chrome version. Can the chrome be taken off somehow or is it permently ingrained in the finish. I will probably use it anyhow but much prefer the original finish. Thanks.
Old Jul 27, 2011 | 11:52 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Are you sure it is chrome plated---------------------or is it just polished? Alum manifolds can be polished to a mirror like finish.
Tom Parsons
Old Jul 28, 2011 | 12:29 AM
Bruce Wayne's Avatar
Bruce Wayne
I'm betting it's polished.
Old Jul 28, 2011 | 02:19 AM
corvettecsn
It's whatever the finish edelbrock puts on it. Can it be removed ?
Old Jul 28, 2011 | 02:23 AM
corvettecsn
I just looked at their site. It is polished. Any way to make it look cast?
Old Jul 28, 2011 | 04:23 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
bead/media blast it, or send it to Jerry MacNeish.
Bill
Old Jul 28, 2011 | 08:19 AM
DZAUTO's Avatar
DZAUTO
A polished manifold has had the original cast surface finish completely smoothed away. Therefore, you can never return it to that original rough, dull surface finish. ALTHOUGH, blasting with a COARSE meadia material will somewhat duplicate a natural cast finish and will also make it dull. If it were mine, that's what I'd do first.
Tom Parsons
Old Jul 28, 2011 | 08:27 AM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
they also have a coating called Endurashine - it is like a coating.
wether it is chromed or polished or coated - you can blast it and return it back to raw alum. - then do whatever you want.
correct as above - if you use coarser material - the coarser the finish will be.
Old Jul 28, 2011 | 09:04 AM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
I'd leave it polished. It's not like it's original or anything, and it's a lot easier to keep clean, polished. Those are about 100$ more than a normal one when new.
Old Jul 28, 2011 | 11:19 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Since it's not a Corvette manifold, why bother? The Torker is not even close to the factory configuration even if the finish were similar.
IMO, performance will be better with a corvette aluminum dual plane manifold anyway.
Old Jul 29, 2011 | 12:52 PM
Kerrmudgeon
I agree with Larry, and if you want to run Edelbrock get the newer RPM Performer model for better low end grunt. Torkers are 70's technology for high rev performance.
Old Jul 29, 2011 | 04:43 PM
davewh's Avatar
davewh
I also agree with Larry
To chrome manifold
