L79 timing question
Old Aug 15, 2011 | 05:09 PM
  #61
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Originally Posted by Brumbach
Excellent suggestion. I'll call Paragon and see what they have to say. They're reputable so surely they'll assist in resolving the problem. One question...is this not a common problem?
Not common at all, get a new one, or like I said try any old Chevy dizzy that you know works, or go to a corner garage and see if they have an old one. Too bad you're so far away, I've got 2 or 3 lying around. Try your local corvette club. Paragon will take care of you. that's the first stop.
Old Aug 15, 2011 | 06:06 PM
  #62
Brumbach's Avatar
Brumbach
Since I paid around $400, I'll wait to see what Paragon does to resolve. I've been asked to call back tomorrow when a more experienced tech is available. The individual I spoke with today seem to understand the problem however. Wonder if Paragon monitors this forum? I know some of their competitors do. Right Volunteer Vette!
Old Aug 15, 2011 | 06:15 PM
  #63
MikeM's Avatar
MikeM
Look at it this way. You bought a replacement distributor for an L 79. The timing curve on what they sent you in no way resembles the timing curve on an L 79. Did they send you new initial timing specs or other info to indicate the distributor they sent you was something other than a direct replacement?
Old Aug 15, 2011 | 06:34 PM
  #64
Brumbach's Avatar
Brumbach
Nope.
Old Aug 15, 2011 | 06:45 PM
  #65
midyearvette's Avatar
midyearvette
You're right on the high end but at low rpms it was really choppy. Had to drive in low gears at low rpms. No vac advance.....
vac advance wont help that condition, think about what you are saying, at low rpm with any throttle opening, vacuum will drop
you need more mechanical advance in the new dist and not necessarily in that soon
you can change your curve with lighter springs or go heavier springs and more initial
then hook up the vac can to see if the mill likes it
im guessing you needed more initial with the mallory too
maybe that curve needed toyed with
power time the mill vac. disconnected ..try 36-38 total all in at 4000 or slghtly under
then see where your initial sits at idle as others have suggested
if it does total out at 5k as others have posted, i think you could use 15 deg initial and the vac can, maybe.....jmo.....
initial timing is what gives best low speed throttle response
Old Aug 15, 2011 | 06:50 PM
  #66
Powershift's Avatar
Powershift
Paragon offers TWO distributors for these cars: one is for 1962-74 without SHP and the other is 1963-74 with SHP. Both exclude FI and TI. This covers a lot of territory.
I would not expect either distributor to be an exact drop-in for my car. I would expect the need to check and modify for my specific car. But I would expect something closer to the factory curve than what Brumbach got. Let's see how it goes.
Larry
Old Aug 15, 2011 | 07:03 PM
  #67
Brumbach's Avatar
Brumbach
I said it wrong. At low speeds, I had to drive in low gear with the mallory. Not the situation with the new distributor. I can drive in 4th gear @ 25 mph. Real smooth too. Not sure how much vac is operating or advance at the lower speeds. You obviously do. I can only describe the difference in the two distributors relative to driveability. With the new distributor, 24 degrees is the best I can achieve without changing the initial timing above 10 degrees. (with vac disconnected). I agree, I need more initial advance, 12 more degrees (for a total of 22 degree) to get the 36 degrees. That's where it's setting now. No problems but would like to get to something near to spec someday. I don't want to go back to the mallory (mechanical advance only).
Old Aug 15, 2011 | 07:05 PM
  #68
Brumbach's Avatar
Brumbach
Larry
Amen. Close is good enough for me. Doesn't have to be dead on.
Old Aug 15, 2011 | 07:13 PM
  #69
Jackfit's Avatar
Jackfit
Default its the shaft
Larry
as I said before , the replacement shafts have a different football shape
midyearvette had to re-curve it , all new shafts or distributors HP or reg need to be reset, to get proper timing
You need a new combo of springs and initial timing to set it up
Tell them Frank
JACK
  #70
midyearvette
I said it wrong. At low speeds, I had to drive in low gear with the mallory. Not the situation with the new distributor. I can drive in 4th gear @ 25 mph. Real smooth too. Not sure how much vac is operating or advance at the lower speeds. You obviously do. I can only describe the difference in the two distributors relative to driveability. With the new distributor, 24 degrees is the best I can achieve without changing the initial timing above 10 degrees. (with vac disconnected). I agree, I need more initial advance, 12 more degrees (for a total of 22 degree) to get the 36 degrees. That's where it's setting now. No problems but would like to get to spec someday. I don't want to back to the mallory (mechanical advance only).
there is something amiss on the curve of the new dist.
from what i am reading, you are saying the advance of the new dist. is only 14 degrees??......36 minus 22=14
i would think you should have at least 20-22 mech. (crank)???
something is stuck or the dist needs replaced for you to acheive what you want and i agree, the curve doesn't need to be right on to spec, but a lot closer than you have
where did you set initial for the mallory??
Old Aug 15, 2011 | 07:25 PM
  #71
Brumbach's Avatar
Brumbach
Mallory: 8 degrees initial. I never did set the total timing, however. The car screamed with it just sucked at low speeds.
Old Aug 15, 2011 | 07:33 PM
  #72
midyearvette
i bet if you power timed the mallory, it would have fallen in around 15-18 deg initial!
Old Aug 15, 2011 | 08:00 PM
  #73
Powershift's Avatar
Powershift
I'm going on memory from 40+ years ago, but I remember that the Mallory replacement distributors of that time had about 22 to 25 degrees (crank) in their curves. So, an initial of around 15 degrees would be needed for maximum performance.
Larry
Old Aug 17, 2011 | 06:03 PM
  #74
Brumbach's Avatar
Brumbach
Well, I still talking with Paragon. Apparently, the vendor is no longer making the reproduction unit. I was hoping they would send out another to replace this one. They did speak to the vendor and he stated that the one I have is a condensed variant that covers a number of vettes. I would've expected that since this one is for SHP 327 it would at least be close to the original spec. I asked Paragon about their rebuild components, specifically the inner shaft with the football for the SHP and would it possibly correct the problem. The tech said it would be identical to the one in the reproduction unit. They wanted to talk with another source and get back to me. I'm beginning to wonder if I wouldn't be better off asking for a refund and pursuing an aftermarket unit. Any look-alike, point-tach drive units that'll perform near to the required spec?
Old Aug 17, 2011 | 06:11 PM
  #75
MikeM's Avatar
MikeM
.....he stated that the one I have is a condensed variant that covers a number of vettes. I would've expected that since this one is for SHP 327 it would at least be close to the original spec. Any look-alike, point-tach drive units that'll perform near to the required spec?
The only Vette's that have a curve like what is in your distrubutor are ones that are set up for straightt line acceleration.
Personally, I would send it back as I said WAY back in this thread. What I see wrong with what you have is too fast advance rate in the centrifugal advance, not enought total centrifugal advance and too much vacuum advance. In other words, like I said early on, this thing is not what I think you need and is nowhere close to stock. Keeping in mind that "stock" can be improved upon.
Old Aug 17, 2011 | 06:20 PM
  #76
Brumbach's Avatar
Brumbach
I agree. I was hoping this one was defective and they would replace it. Since that's not an option, I'll give them a little time find a solution before I ask for a refund. Do you have any recommendation for a new distributor? I'm not interested in new technology. I prefer good old points and of course need the tach drive. Meanwhile, I can return to old faithful Mallory (w/o vac).
Old Aug 17, 2011 | 06:27 PM
  #77
Powershift's Avatar
Powershift
I recognize that you paid $400 for this distributor and want it to fit and work correctly. And for that price it should.
At this point you can:
1. Keep what you have. Work with it and revise it to better suit your car. Jackfit did this a month or so ago and was successful.
2. Send it out to some else who can do this for you. More $$ but a good end result.
3. Return the unit. Buy and refurbish a good used Corvette distributor. They are available on Ebay, at Carlisle, Corvette Forum Parts for Sale, etc. etc.
4. Return the unit. Buy another aftermarket distributor (Accel, Mallory, etc) and and work with it to make it right for your car.
5. Wait on something from Paragon.
If it were me personally, I would keep it and work with it to make it right. Or I would box it up and sent it to www.tispecialty.com for rework. The final product should/will last a lifetime.
Good luck.
Larry
To L79 timing question
Old Aug 17, 2011 | 06:56 PM
  #78
Jackfit's Avatar
Jackfit
Default I agree
Good luck.
Larry
Agree , and {op} listen to what has been said, what was good then, as specs, need tweaking today, to deal with today,s products and their different characteristics, even if stated as "exact repro products " , I am not saying that they are bad, just need to be adjusted by old school know how.
Jack
Old Aug 17, 2011 | 07:47 PM
  #79
Donald #31176's Avatar
Donald #31176
Find yourself a Delco tach drive w. VAC 63-74 vintage thru Ebay and have it recurved & blueprinted from the source that I mentioned to you.
Old Aug 17, 2011 | 11:17 PM
  #80
midyearvette
run your mallory and set the initial at 15 deg below 800 rpm
take the car for a ride and check for pinging, if so back it off in 2 deg increments
shoot for 38 deg total.....
