C1 Overheating
I've been lurking here for a few years. I'm helping my father in law keep his 62 running. He bought the car in the early '70s. It had a 350 in place of the original engine and he later (~25 years ago) found and installed a (from what I've read out on the web) 1966 327. I don't know what else isn't original.
After tinkering my way through timing and carb adjustment, both of which I now understand can contribute to overheating, it runs pretty well. Clearly now though I should have someone with a clue check that timing and mixture to make sure I'm not adding to the overheating problem.
We ordered a new Dewitt radiator for it last fall, but I haven't installed it yet. After reading through the FAQs and sticky posts on the C1, here's what I'm thinking:
1. The fan clutch and fan are probably not original. The fan is too small (1.5=2" clearance to the shroud), and too far aft (not halfway into the shroud fore and aft - completely behind the shroud). The fan is bolted to the engine, there is no clutch.
2. The radiator doesn't seem to be original, not that that really matters since I'm replacing it anyway.
3. The shroud appears to be original or at least looks like it was meant to be there.
I've replaced the temp gauge sender, and it's accurate according to my IR thermometer.
The car runs cool (160-180) anything over ~30mph, but heats up quickly at idle.
So I'm guessing part of the idle heat buildup problem is that misfit fan setup. Should I just go find an original fan and bolt it in there? Are these things even floating around anywhere at a reasonable cost?
Pics, if you're interested:
https://picasaweb.google.com/1113834...26093/Corvette
Any input appreciated. Thanks!
John F
The two hoses connect to the engine at the top of the intake manifold by the thermostat housing, and on the side of the water pump. You can see both connections here:
https://picasaweb.google.com/1113834...69293093782530
I assume that goes as well. Am I just plugging those two holes where the hoses currently connect?
Added a couple other pics to the photos page.
I see now what K2 means, we need to either plug that hole or connect it to fresh air on the firewall. Seems easy enough.
Great input, thanks!
I've ordered a mess-o-parts from corvettecentral. If I were to remove this secondary cooling box and not hook up to the original heater core (because I don't want to get into another project right now), would it be better to connect the two nipples on the engine/water pump, or plug them? Or should I just get into the heater core now.
Here's what I have coming, if anyone sees anything grossly incorrect, let me know. And if nothing else, if these parts are correct, maybe it'll help someone else find part numbers for this stuff.
Thanks!
Product Class Item # Description Style Retail Cost Qty Extended Price
241015 RADIATOR SUPPORT SEAL - HI PERFORMANCE SIDE --- 10.00 1 10.00
241016 RADIATOR SUPPORT SEAL SET - LOWER - 3 PIECES --- 9.00 1 9.00
241017 RADIATOR CUSHION / POWER STEERING CYLINDER GROMMET --- 2.50 3 7.50
241219 THERMOSTAT - 180 DEGREES --- 6.95 1 6.95
241215 THERMOSTAT HOUSING GASKET --- 2.95 1 2.95
241308 EXPANSION TANK HOSE - TO RADIATOR --- 6.95 1 6.95
241305 EXPANSION TANK HOSE - TO WATER PUMP --- 6.95 1 6.95
241405 HOSE CLAMP SET - 327 EXCEPT AIR CONDITIONING - CORRECT WITTEK - 16 PIECES --- 20.00 1 20.00
241150 FAN BLADE - GM REPLACEMENT ( USED WITH 241151 CLUTCH ) 17 5 BLADES --- 104.95 1 104.95
241156 FAN NUT SET - TO CLUTCH AND WASHER - 8 PIECES --- 1.95 1 1.95
241155 FAN CLUTCH - WATER PUMP FINE THREADED BOLT - REPLACEMENT --- 4.95 1 4.95
241151 FAN CLUTCH - SMALL BOLT PATTERN --- 119.95 1 119.95
241202 RADIATOR HOSE - UPPER WITH TOP TANK ALUMINUM RADIATOR --- 27.00 1 27.00
241205 RADIATOR HOSE - LOWER --- 24.00 1 24.00
Thanks, and have a good weekend!
Installed all new parts except the top hose which didn't fit, sealed the sides of the radiator with pipe insulation as Frankie instructed, found and re-installed the original fan clutch, and we're in pretty good shape. It does heat up a little (up to 195-200) after coming off of the freeway and idling for about 15 mins, but doesn't go higher. And when it's idling like that, bumping up the rpm to 1200 or so for 30 seconds starts to cool it off. It didn't cool off like that before.
It's only 55 here today, so the real test will be an 80 degree day, but all in all, I think we're on the right track. Thanks everyone for the help!
https://picasaweb.google.com/1113834...92962508628290
I fought overheating issues with my 60 for years..especially in parades.
then I installed an electric fan in front of the radiator and that cured the issue. suggest to install the largest you can order!
Another consideration is getting a quart of Kooldown from your local Napa that works well too! Somer Farmers use this in their equipment.
ThumperZ06
I've fought this issue for at least 3 years now, I'm giving up and sending the new alum radiator back to Dewitts to have their electric fan mounted.
Questions: Will the generator be ok running that fan? I don't know how much power that puts out at idle. I think I read the fan draws somewhere in the 20A range. Tried a search for that info and didn't find anything, so I assume it's not a problem with the stock generator.
Thanks again for all of the help with this. Looking forward to not worrying about temps at stoplights and in traffic. As is, we've been averaging ~120 miles/year, but I think that number will go up significantly once this is resolved.
