Ok,here's the deal. I've just aquired a '66 coupe that has been parked in a dry garage since 1978. Never moved an inch. Nassau blue with black interior. it's still covered with cardboard boxes and blankets. I'm just uncovering it now so it's going to be an adventure. I know it only had two owners before me, and it's all there. I want to move it out and begin the journey to getting it on the road. You guys are the experts, and I'd appreciate your input as I start looking at codes and #s to see just what I've got, and if it is all original. I've been told it is. I know, you've heard that before. Where would you guys start with the restoration? When it was parked 33 years ago there was something amiss in either the 327 engine or the tranny. Any do's or dont's while rolling it onto a trailer or other advice would be appreciated, and no I'm not going to stick a new battery in it and try to start her up after 33 years. I know my way around cars, but I'm new to Vettes. I'm going to take pictures from beginning to end, and I'll post them here. It's like uncovering a time capsule, and finding a '66 Vette inside.
Welcome abord Packrat66. I too am the proud owner of a 1966 that sat in a garage since 1978, mine went in with Engine and rust issues and that is how I bought it 4 years ago.
With two son's in college I have waited to start this project, I bought it thinking I needed to buy before they went out of sight price wise. I should have waited. I could have picked up a much better deal today.
This forum is full of great guys that really enjoy the C2 and offer many great idea's, most from direct experience and that is invaluable.
Things to start with.
Don't trust the electrical at all or you can fire up the whole car.
The brakes will be toast. Drain fluids and flush, hope for the best but most likely they will need rebuilding all the way around. Rubber rots with age, when usede daily or parked.
Antifreeze needs to be drained and the system flushed and checked.
Freeze plugs in the engine may be completely rusted out after this much time.
Exciting to hear of another coming back from the dead.
Good luck and keep us posted, WITH PICTURES.
Thanks for the welcome advice guys. I'm going to the garage today to start the excavation. You'll understand what I mean when you see the pictures. You guys have given me some great advice so far and I will take pictures as I go. I know it's not some rare 427 that they only made two of or anything, but any '66 Vette is a good Vette in my book. Like I said I'm a newbie to Corvettes so this looks like a great place. I'm looking forward to bringing this machine back to life, and sharing it with knowledgable people who can give me some help along the way. Later!
welcome to the "dark side", packrat66.....patience here will be rewarded later on....you will receive help here for your de coding. then you will know what you have and how to go about your goals. fwiw, do not attempt to turn the mill over, even by hand! once you are able to delve into this, there is a systematic approach to all your concerns.
obtain a good digital camera and clean out a resting place for the project. not knowing how you are tooled up, my first suggestion is to buy 4 quality jack stands and at least a 2 1/2 ton floor jack......
Thanks Midyear. I've got the floor jack and jack stands. I'll have to fill the tires, and make sure she's out of gear when it's time to load her up. This car has not moved an inch, except down, in 33 years. Later with pics.
..I'd appreciate your input as I start looking at codes and #s to see just what I've got, and if it is all original.
For starters, write down the numbers/letters you find here:
Cast into intake manifold
Cast into left rear of block
Cast into right rear of block
Stamped into front right pad of block, just forward of right head
Stamped into carburetor
Stamped into alternator
Stamped into top of radiator
Stamped into aluminum band around base of distributor
Case and stamped into transmission (several places)
Stamped into bottom of rear axle pumpkin
Stamped into VIN plate (under glove box)
Stamped into TRIM plate (under glove box)
Etched into windows under the LOF logo (look in the bottom corner of the windows)
That will get us a starting point on what your car has, is, etc.
Figure out what you have by getting us the numbers above
Show us what kind of shape the car is in by posting photos as requested earlier
Determine what your goals are for the car
If you decide to restore it, ask a lot of questions here first. You'll get a lot of advice, and a lot of opinions, you'll need to wade through ti all to figure out what makes the most sense for your situation.
If you decide to do a full restoration yourself, don't understimate how much that can cost.
air up the tires
be prepared for one or more of the wheels to be stuck due to brakes (front) or brakes/parking brakes (rear). The rear parking brakes are inside the rear brake disc, like a miniature brake drum. Not easy to unstick if they are rusted up.
Dose it look anything like this? This one was parked in 1978 and never touched again till I pulled it out a few years ago.
I found that the orig. steel shim head gaskets had rotted after sitting all those years. I pulled the motor without even trying to start it. You may want to do the same thing.
Just to give you some inspiration. This is after a nut and bolt frame off.
You Might Also Want To Check the Interior or the Car...
and the engine compartment for any evidence of insects, rats, mice or other "critters" that have taken up residence in the vehicle. The last thing you want to do is push it into your garage and find out you have a "critter" infestation on your hands..
Before doing much, begin with simple soap and water washing of everything to see what you find. Intense scrubbing can destroy chalk marks, grease pencil markings, and such that were put on during the assembly.
Like one said, get a digital camera and take pictures of EVERYTHING and do it often as you disassemble. It will be invaluable putting it back.
That long, odds are the engine won't budge, but if the car looks really good, you might try to turn it over by hand and do some minor things to get it so you can get a Bloomington Gold Survivor award.
You'll need to upload them to a tinypic or photobucket account first. Those sites are free, you just have to create an account and upload your pictures. Then see this thread:
Ok, here we go. Please note the Christmas tree complete with train set on the top of the car. It took my son and I 5 hours today to slowly uncover and sort through all the junk on top of the car. Next up a look under the hood and inside the interior.
Thanks guys. There is almost as much stuff inside the car as there was outside. That's up next. The good news is that we can see Corvette parts and pieces under some of the other stuff stored in back of the seats. The dash and front seats look good, but we need to get her empty to make a full assessment. We are working at cleaning the rest of the home while we work on the car getting it ready to move. Otherwise we would have it all cleaned out already. We may not get back to it for a few days, but pictures of the interior and engine compartment will be coming. The front bumpers are off, but they may be in the back of the car or someplace else in the garage. I know, I know "what's taking this guy so long?". If you can imagine a house that is as equally buried in stuff as the Vette you'll get the picture. Thanks for the help so far everyone. The journey continues.
If it's as bad as those homes on that Hoarders show, you have a LOT of work ahead of you.
BTW, nice planning for whomever put the car away with the headlights open. The driver's side headlight bucket appears to be preventing an avalanche .
