assemble 62 windshield?
Old Sep 3, 2011 | 05:25 PM
dcrocker316's Avatar
dcrocker316
Default assemble 62 windshield?
I need step by step instructions for assembly of a 62 vette windshield. If you can help send instructions to cromecinc@citcom.net . Thanks, Dave 864-380-4796
Old Sep 3, 2011 | 05:37 PM
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
Use the search function
http://forums.corvetteforum.com/c1-a...-assembly.html
Old Sep 3, 2011 | 05:43 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Try this out:
http://www.sssacc.org/Tips/Windshiel...eplacement.pdf
Old Sep 3, 2011 | 11:33 PM
Larry P's Avatar
Larry P
The above info is very detailed. The link above that has a link to my site that has been discontinued. The correct link is
http://www.gatewaycashregister.com/car_site.html
It's not as detailed but has a pretty good list of the components and
some tips that I found usefull when I did mine.
(The windshield part is below the YouTube video)
Larry
Old Sep 5, 2011 | 08:25 PM
gr8corvette's Avatar
gr8corvette
Gr8Corvette
Part 1 parts list image just has a little red x???
Old Apr 18, 2012 | 08:08 AM
lbjrobb's Avatar
lbjrobb
1st Gear
Default Windshield 1961 back on car
Can some one Help me here
I have this on and off the car 4 times
When I bolt Windshield to car the windshied frame spreads and the glass comes out of rubber
are parts a new and fit great on the bench
all most like fram spreads or glass too small
Old Apr 18, 2012 | 08:52 AM
mike coletta's Avatar
mike coletta
You have one of the following:
1. The tabs are broken or incorrectly repaired.
2. The windshield channel is not straight (usually caused by a new surround or nose improperly installed on the car.
3. Not enough shim on the post studs
The glass is not too small. When the frame is assembled, and not on the car, you should not be able to push down on the header (center), and have any amount of "play". If it feels tight, try adding some shims to "hold" the post in a more upright position when you install it on the car. Keep in mind that the rubber shims under the post will compress if you tighten too much. If you have to use more than 4 shims (special rubber type), then you have something else wrong. The "normal/typical" is two or three. Also keep in mind that as you shim the posts, you move the latching points for the top (hard or soft) forward. If the top frame is not adjusted correctly, it will "pull" the header loose from the glass.
Mike Coletta
To assemble 62 windshield?
