Rear Diff Fluid
Old Sep 6, 2011 | 12:39 PM
DJ's Car's Avatar
DJ's Car
Default Rear Diff Fluid
I have a 1960 vette and on the rear diff it says 'Only use limited slip fluid' (or something close to that). What should I be using?
Is the regular 90 weight gear oil not correct?
Thanks for the input.
Jim
Old Sep 6, 2011 | 12:50 PM
JohnZ's Avatar
JohnZ
You can use 75W90 or 80W90 hypoid lube with a bottle or two of GM Limited-Slip additive.
Old Sep 6, 2011 | 12:52 PM
DJ's Car's Avatar
DJ's Car
Exactly what I need to know.
wmf62's Avatar
wmf62
St. Jude Donor '07
the weight is OK, what you MUST add is a couple of bottles of the limited slip additive available at your GM dealer (however, i have been told that the Ford additive is better,)
Bill
To Rear Diff Fluid
