I know the AC45 is a hotter plug but does that mean the engine will run hotter, over heat. According to manual the 44 is original equipment, but the way I drive my car, short trips around town, I'm wondering if the 45 is what I need. But then again, I do not want the engine to overheat.
From: The problem is all inside your head she said to me.
Someone can correct me if I'm wrong but I don't believe one step or many would make the engine run hot. It has to do more with the life of the plugs and weather they are fouling or not. The insulator is different in a hot to cold plug to keep the tip hotter or cooler to fire the mixture, not heat or cool the engine.
one range hotter will not overheat your engine, although it will raise combustion temps by one range, it will not tax the cooling system
a lot of c/f users use the 45 range
hope this helps.....
These cars generally run rich ESPECIALLY the dual quads...run AT A MINIMUM AC45. At one point GM released a service bulletin to go even one range higher (AC46) for anti-fouling. You will not find AC46s but, if you need them, there may be equivalents out there.
The spark plugs in your engine need to run at least 850*F to keep the plug from fouling.
Hotter plugs will raise the temperature of the PLUG tip, not the engine. Colder plugs will LOWER the temperature of the PLUG tip.
Doesn't have anything to do with engine operating temperature.
I agree, and yes 45 or 46's are a better plug running locally in town traffic. The best result is to pull several plugs after 500 miles and see if they are black, med brown or yellowish. Then make the proper plug changes. Med brown is the best range, black is too rich or cold, yellowish is way too lean or hot.
rustylugnuts
Reason: changed to 45 to 46
One more question. The resistor plugs, (R45) are for what. In other words, what do they mean by resistor. IS it to help with radio noise..
Resistor plugs have more resistance to accommodate or relieve static noise when you are having static sounds/conditions through your speakers when radio is playing. A non-resistance plug is much better in performance for your engine, but the static coditions may be present. (it's a trade off)
rustylugnuts
rustylugnuts
Not necessarily. With unleaded gas, white or off-white insulators are quite common with correct mixture.
He says he runs 100 LL AV gas so that might put some color on the plugs.
If the Florida DOT does a fuel check on him, do you think they'll put the hook on him and impound the car for illegal fuel?
No, on an old car, pre 1968, there are no fuel requirements from emission laws.
However, the taxman might get him. Running av-gas, he isn't paying all the state and federal taxes and is therefore illegal.
Then again, there are so many laws most of us break without ever knowing it, I doubt anyone has to worry about people checking our gas.
Although about 20 years ago, Ohio was pulling race car trailers over to check if they were carrying fuel. You were only allowed something like 5 or 10 gallons and a lot of guys going to the SCCA Run Offs were carrying far more than that for their week long racing championships.
