C2 Window Crank Knobs - Removal Question
Old Sep 12, 2011 | 02:46 PM
babbah's Avatar
babbah
Default C2 Window Crank ***** - Removal Question
How are the ***** (not the cranks themselves) on the window cranks removed? I see that there are 2 pieces - the **** and the stud or screw (backside of **** on handle). Do you just pry the stud from the back of the handle to remove the ****?
The stud looks like a screw with threads that secure the **** to it and it free wheels when opening/closing the windows.
Thanks!
Old Sep 12, 2011 | 03:07 PM
Stingray1967's Avatar
Stingray1967
They're riveted on from the factory.
Ideally, you'd have the whole crank off the door panel before trying to remove the **** from the crank.
Why are you working on those? Are they loose? If so, you can peen over that rivet some more to tighten them up.
Old Sep 12, 2011 | 04:26 PM
babbah's Avatar
babbah
It's not a rivet, it has threads inside holding the ****.....going to refurbish the *****....and yes wih crank removed....
Old Sep 12, 2011 | 04:28 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
then its been repaired in the past. every **** i ever seen was riveted together
Old Sep 12, 2011 | 05:12 PM
Powershift's Avatar
Powershift
Larry
Old Sep 12, 2011 | 05:41 PM
Stingray1967
Can you post a picture of what you have? Sounds like a repair has been made to them in the past.
Old Sep 12, 2011 | 07:39 PM
Bill Lacy's Avatar
Bill Lacy
If this is what you are talking about. These are originals. Its a stud that has been pined over.
Old Sep 12, 2011 | 07:42 PM
babbah's Avatar
babbah
The replacements pictured is what I had described as a screw.
Ok - Mine are the originals - never been touched - (I'm the original owner) so it must be a rivet - How do I remove the **** with the rivet? Drill out the rivet?
Thanks!
Old Sep 12, 2011 | 09:28 PM
Nowhere Man
drill out the rivet or grind off the penned over part. and it should fall apart
To C2 Window Crank Knobs - Removal Question
