Muncie Question
Even with engine out I was having trouble moving shifter (stock shifter). I took out the shifter to rebuild/clean and found the interlock lever was broken, probably causing it to block the shifter from moving to other positions. Replaced interlock. Next I went to drain the fluid to examine condition and check for filings, but found that there was no fluid in case. Then I pulled off the side cover to get a visual inspection - everything I could see appeared to be in very good shape -no obvious worn or broken teeth.
Should I: 1. Just pull the trans and rebuild, since I am not sure of condition and engine is already out? or, 2. Fill with fluid, re-install shifter, and if it moves smoothly forget trans rebuild at this time - since all that I can see looks good and for all I know the previous owner may have just rebuilt trans 30 years ago.
Is there anything else I can do to determine condition of trans without tearing it apart?
Thanks for any advice or suggestions.
If the shifter works ok, and doesn't have any slop in the linkage, it will probably be fine. Shifter rebuild kits are available from vendors such as Zip.
The problem lies, typcially, with 2nd and 3rd gear and the engagement teeth ON the gears. Also, the brass synchros need to be examined, too, as well as the sliders, and that isn't as easy to determine when they are in the trans as when it is apart. Thirty years is a long time and I would suspect the input and main shaft bearings need to be replaced, as well.
My suggestion is to enlist the service of someone who knows these boxes and have it looked at and, possibly, disassembled and checked. Rebuilding one is easy and you may want to try it yourself. A rebuild kit with new sychros, gears and hubs (master kit includes gaskets, bearings, etc) will run around $500.00
If you elect to not tear it down, at least replace the retainer bearing gasket, the side cover gasket, and the rear seal in the tail. Good luck.
If it was mine, and it was out of the car, I would go through it. You may just need synchros.
I would pull the cover, look at the brass syncros and reciever teeth on each gear. If they are sharp, they should be OK. Check the engagement of the syncro cone to the cone on each gear. If tight before getting close the other surface, it is OK.
Check the forks for wear. If visiable, replace. That is only a minor improvement. Unkown histoy, I would replace all the needles, seals and two roller bearings. They are really cheap. Front fearing maybe $25, main bearing $13. Call Auto gear, ask for George.
Where the oil went, who knows over 30 years. It will not leak lower than the counter shaft usually. Drain plug?? 1966 trans?? M22?? No oil on the 30 year old floor??
As for adding a drain plug is Bubba, is just plain BS. Those of us that accually drive our cars, like these corvettes were meant to drive, we add drain plugs for service reasons.
I did install a M21 in a 62. It still had oil in the transmission when I bought it. Bubba was not there when I did the job.
Now, I did this and have not had any problems so far with the transimission. I did have some linkage problems though that was my fault with missaligned shifter.
Also, I cleaned up the transmission case using simple green or purple power, scrub brush and a power washer. It had some nice patina on the casing.
Also look for obvious broken teeth.
Joe
