1960 generator
1960 generator
Armature looks pretty worn. Generator was giving off a nice odor after a short drive today. It is charging though.
Time to be replaced?
Recommended places to get one?
Tom
Tom
I had this apart about a month ago and installed new bearings and brushes. It seemed to be working well through the engine start up and tuning. I just got the insurance and registration this past week so I was able to drive it on the road this weekend. Yesterday I put about 8 miles on it and nothing major other then some squeeks and rattles. Today I drove it to the gas station and back, maybe 5 miles round trip, pulled in the garage and there was a strong electrical type smell coming from the back end of the generator. I didn't know if this wear could contribute to the smell.
I know of a local alternator shop, maybe they can turn it for me.
Tom
The old guy that does my starters and alternators here in Orlando said that they don't do generators any more, but since I was a regular customer he would rebuild mine when it ever needed it. Most of these shops can do this work.
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
I have to agree with Dan.
If there are no shorts in the armature or in the field coil windings, then have the commutator turned (this was a normal procedure when generators were in regular use) and install new brushes and bearings.
ANY good generator-alternator-starter shop that has been around for a long time can turn the armature and check the field coils. Put it back together and it should be fine. Once installed, BEFORE attempting to start it, polarize the generator at the voltage regulator, and it will be good for many more years. For no more electrical load than these cars require (lights, radio, heater, ign), a healthy generator is more than sufficient to supply the needed power.
Tom Parsons
Dan,
I had this apart about a month ago and installed new bearings and brushes. . Yesterday I put about 8 miles on it and nothing major other then some squeeks and rattles. Today I drove it to the gas station and back, maybe 5 miles round trip, pulled in the garage and there was a strong electrical type smell coming from the back end of the generator. I didn't know if this wear could contribute to the smell.
Tom
Tom
Take it to the old guy. It will need undercut as well as turned on the lathe. It is well worn. The old guy will be able to tell you if there is enough copper left for a good cut and still be reliable.
ANY auto electric business. I replaced one in my friends 59 last year. I called two different places in town. One said "I can have it here tomorrow", the other said "I have one on the shelf". Less than $100 including tax. It's the same armature as the power steering generators of days gone by.
Jim
Jim
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
Jim
Jim
Jim
Jim
Another source would be an Electric motor rebuild company. I had mine rebuilt this way because it was beyond turning. I went this route because I found new and rebuilt generators but not a tach drive. This was awhile ago so I don't know a realistic cost at todays prices anymore or even a good guess.
Jimmer
Jimmer
This just happened to my 62's original generator. It was certainly a very distinct smell. Needed a new armature. Found a guy here on Long Island. Did a great job, generator looks like new. Cost me 135.00 dollars. Checked my VR as well.
I think I have a couple of these laying around the shop, I use alt. so they are of little use to me. I would be willing to let them go cheap in as in condition.
I need to look tomorrow and make sure.
Speaking of generators...If you do not have sealed bearings what kind of lube do you put in the little holes on the front and back????
I would guess mine (1959) has never had any added, probably about time to!
