Quick Timing Question
Old Oct 5, 2011 | 02:55 AM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
Default Quick Timing Question
My car is not running terrible, but I wanted to see where it runs the best. The vacuum advance can is snug against my coil. Can I get more adjustment by pulling the distributor and rotating it counterclockwise one tooth? I'd like the can in the middle, between the coil and manifold. Also how do you know where the timing should be if you don't know anything about the engine's insides. Do you go with highest RPM's? Highest Vacuum?
Old Oct 5, 2011 | 05:43 AM
MikeM's Avatar
MikeM
If your vacuum can is dead against the coil and the coil is in the proper location and the cap wired correctly, it's likely you timing is either too slow or too fast.
You need to put a timing light on your engine, find out what the timing is and then adjust as needed. If you can't adjust as needed then you likely will have to pull the gear on the distributor shaft and rotate it 180* and re-install, re-time the distributor.
Most SBC's will run best with 10-15* initial timing but that depends on the mechanica advance limit and the vacuum can.
Old Oct 5, 2011 | 01:35 PM
KC John's Avatar
KC John
Problem is I don't know where the timing should be set. Also my question was if I move the dist one tooth, will that give me more adjustment, or will it put me too far the other way.
I would like to take the easy way out and move it a tooth rather than flip the dist gear if possible. I know that flipping the gear is the same as a half tooth, so I don't know if I can get away with a full tooth and have adjustment both ways.
Old Oct 5, 2011 | 01:59 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Move it one tooth in the direction you want the can to move, then retime. No big deal.
Old Oct 5, 2011 | 03:13 PM
MikeM's Avatar
MikeM
Typically, on a midyear, moving the gear one tooth will run you into interference the other direction. He doesn't state where the timing is now so why should he move anything until he finds out where he is?
Doesn't make any sense to me.
Old Oct 5, 2011 | 03:16 PM
LB66383's Avatar
LB66383
Disconnect the vacuum advance, connect a dial-back timing light, run the engine up to around 3,000 rpm (or wherever the timing stops advancing, and see what it is. It should be 34-36*. If it isn't, try adjusting the distributor. If the coil is in the way, move the dizzy one tooth and try it again.
Old Oct 5, 2011 | 04:03 PM
KC John's Avatar
KC John
Mike, the timing is at about 13º advanced. That is as low as it will let me move it. I would just like to be able to see if it runs any better if I had the initial timing set at 10º.
I know by rearranging the plugs over 1 tower, it will be too far the other way. I wasn't sure if turning the dist only 1 tooth will make the can hit the manifold also.
Old Oct 5, 2011 | 04:13 PM
JohnZ's Avatar
JohnZ
If you move the distributor one tooth, that will rotate it 28 degrees, which will probably make it hit the #8 intake runner. Pull the distributor and flip the drive gear 180*, and it will rotate the distributor 14*, which should put you just about centered between the two interference points.
Old Oct 5, 2011 | 04:25 PM
midyearvette's Avatar
midyearvette
it wont run better at 10 deg vs 13 deg.....
Old Oct 5, 2011 | 04:51 PM
MikeM's Avatar
MikeM
Pull the distributor and flip the gear and you'll have the vacuum can where it belongs.
Timing at 10*-13* won't make much difference if any. I'd still flip the gear just to make things the way they're supposed to be. thumbs:
Old Oct 5, 2011 | 05:52 PM
KC John's Avatar
KC John
Thanks guys, that's what I thought. I'll pull the distributor and get the can in the middle, that way at least I can see where the car runs better.
To Quick Timing Question
