67 Overheating Need help PLEASE
thanks
JR
There's really no reason why a (quality) replacement brass radiator shouldn't do the job although the DeWitts would have given you a bit more cooling capacity.
Steve
Copper/brass 3290btu/min $400
Replacement aluminum 4100/btu/min $525
Restoration aluminum 4600/btu/min $875
With the copper replacements 30% less capacity than the original it baffles me how anyone could say they "should be fine". I don't understand why dealers continue to even offer them.
If you are on a budget and need a good replacement this is the way to go. Our Direct Fit (A63M) is a nice looking radiator with similar performance (10% reduction) to the stock radiator.
with this. Get an infrared tester and get the right temp readings before you go spending tons of money! Take reading at lots of places on the motor (block) and rad. I hope the block was cleaned out well before being assembled, otherwise sediment and rust could be the problem. Good luck!
Is that fine? Well, it is for me considering the money I saved. It hasn't ever boiled over or gotten any hotter than 205*. Also, when the temperature gets in the '90's, I don't consider it a pleasant experience to be driving around in a non-air coupe anyway.
Some people have to see the temp gauge on 180* max or they panic!
On the other hand, a new replacement aluminum radiator from DeWitt's isn't a bad idea.
Assuming everything else is set up properly ie: clutch fan, radiator seals, timing and vacuum advance you will benefit from an aluminum radiator. Tom knows of what he speaks. I would much rather run 180 than 205-210.
1. Cap isn't holding rated pressure (15 psi), reducing boiling point.
2. Expansion tank is over-filled, expanding coolant has nowhere to go except out of the overflow (it should only be 1/2-full, cold).
3. Coolant won't boil until 265*F with the correct 50-50 mix of anti-freeze/water and the correct 15 psi cap; what does the temp gauge show when it pukes, and what does an I.R. gun "shot" of the upper radiator hose just above the thermostat housing show when that occurs, and how does the I.R. gun reading compare with the temp gauge reading at the same time?
Do you have the correct fan, clutch, and shroud? Everything in the cooling system better be in top shape if you have a copper/brass radiator. Read this if you're not familiar with how a Corvette cooling system works:
http://www.lbfun.com/warehouse/tech_...em/cooling.pdf
When someone posts the car is "overheating" I assume they mean temperature and not expanding out due to being over filled. There are way to many previous threads in the history to ask all the obvious questions.
Zee, you have to understand that GM designed all midyear small block cars with the same 4600btu rated heat exchanger, that included a 250HP base motor and a 365HP FI car. Some cars generate less heat than others due to tons of variables, most of the variable modifications (IE overbores, stokers, special cams, trick stuff, tuning and timing). Then throw in different climate areas where one guy has 80 degree summers and the next has 110 degree days.
Everyones engine is different these days and the perception of "fine" is as well. This year at Carlisle someone said his copper radiator works fine as long as he didn't drive it when it was over 80 outside. Too me, that's not fine. Then you have the guy where the copper unit does the job and maintains the engine temps below 200, which is great. It doesn't change the fact his radiator is 2/3 the rating of the original. For him, 2/3 is enough and he might conclude that all this stuff about aluminum is just propaganda.
