paint stripper
Old Oct 12, 2011 | 01:27 PM
wfortune@snet.net's Avatar
wfortune@snet.net
Default paint stripper
I'm thinking of stripping the old paint and then filling in low spots.
What should I use, void of a body shop enviorment, doing this in my garage!
Lt.C.
Old Oct 12, 2011 | 01:39 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
What are you stripping? I used Capt. Lee's on my '64 and it worked well, but it won't touch the primer underneath. For that, you sand it off or use Soft Scrub(yeah I know it's for scouring your sink!) and red Scotchbrite pads to rub it off.
Have fun, it's a lot of work, but worth your time in the end.
Old Oct 12, 2011 | 02:59 PM
1snake's Avatar
1snake
Kleenstrip Aircraft Fiberglass paint remover #GAF 354. I've used it on several Corvettes for 30 years. Works great and zero problems.
Jim
Old Oct 12, 2011 | 03:22 PM
mrg's Avatar
mrg
Jim
Also used this same paint stripper on my car with good results and zero problems. This paint stripper appears to be aggressive enough - just not overly so.
Interesting that on the back of the container the product warning label says "DO NOT USE ON AIRCRAFT" ..
Works just fine on Corvettes, though.
Old Oct 12, 2011 | 03:35 PM
wfortune@snet.net
Thanks,
Once the paint and primer? are off, what is best as a filler and can it be applied any other way but spray?
Lt.c.
Old Oct 12, 2011 | 09:27 PM
DansYellow66's Avatar
DansYellow66
Originally Posted by wfortune@snet.net
Thanks,
Lt.c.
Evercoat makes readily available, quality products. Rage Gold seems to be a favorite with the Cobra replica crowd. I've been through 3 gallons of it and can't find fault with it. I read an interesting paint article in Auto Restorer a few months ago on re-painting a fiberglass car. After stripping the paint he firsts prayed the raw body with epoxy primer. Then he did his filler work/blocking and then finished with another couple coats of epoxy primer. The theory was the epoxy primer sandwiched in the filler and prevented anything from reacting with it from through the fiberglass underneath or from the new paint on top. I know your trying to stay away from sprayable high build primers, but its something to consider.
Old Oct 12, 2011 | 09:51 PM
1snake's Avatar
1snake
I use Evercoat products exclusively.
Jim
Old Oct 13, 2011 | 09:10 AM
Mike Geary's Avatar
Mike Geary
Jim
Yep, that's the good stuff. Hot enough that the wait time is reasonably short. Less opportunity for wicking/impregnation to cause problems later.
As mentioned in another post, shooting a coat of epoxy/slicksand/featherfill before applying filler is frequently recommended.
I use slicksand myself, or "polyprime" from PCL. TCP global carries it.
Old Oct 13, 2011 | 09:31 AM
Vette Daddy's Avatar
Vette Daddy
Using Captain Lee's today on a 64 conv.
Old Oct 13, 2011 | 09:43 AM
wfortune@snet.net
thanks to all you guys, i'm sure I'll have more questions.
Lt.C.
OH OH, one more thing.
Can the filler be applied any other way but spray?
Old Oct 13, 2011 | 02:05 PM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
I use Marson Platium filler
owned by 3M
It is one of the best premuim filler
http://3mcollision.com/products/fill...ler-01131.html
I have used alot of fillers
I use Slick Sand over the top of fillers and raw or exposed glass
http://www.evercoat.com/productdetail.aspx?pid=28
To paint stripper
