61 Offset wheel/tire setup
Old Oct 22, 2011 | 07:56 AM
southfloridagas's Avatar
southfloridagas
Default 61 Offset wheel/tire setup
First thank you guys for your tips as I have my car is coming along. I am dropping a 383 stroker in with a tremec 5 speed. I would like to get a little more meat on the rears to help hookup but was wondering what anybody has done with different backspace options, offsets etc to keep the original look hubcaps etc without chopping the inside. Thank you again guys.
Old Oct 22, 2011 | 01:32 PM
QIK59's Avatar
QIK59
I run 6" or is it 7" Monte Carlo Rally wheels (different offset) than the vette ones - they center perfectly.
The biggest deal is to use rounded sidewall profile tires - you can't run the newer style "square" profile tires in a 70 or 75 series (15") without rubbing the rear fender lips on bumps.
Old Oct 22, 2011 | 03:32 PM
devildog's Avatar
devildog
From: fighter pilots make movies, bomber pilots make history
Kris,
i just did the same to my 61 (400 DART engine). Here is my post with pics from Feb 2011.
http://forums.corvetteforum.com/c1-a...ear-tires.html
i think this will tell you all you need, several of the others helped me sort out what was the maximum rear wheel/tire.
Joe
The two main things to watch:
1.Tire clearance vs leaf springs
2.weld numbs (cant say **** on this forum) on wheel to hold full face hub caps.
Old Oct 22, 2011 | 04:30 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
7" rim with 4-1/2"bs with 215x70x15 is the most backspacing for that size tire. can get a finger between tire bulge and spring leaf. more than an inch clearance outward. adjust backspacing to suit tire width.
Bill
To 61 Offset wheel/tire setup
