Rear harness,socket bulb problem
Old Oct 24, 2011 | 05:20 PM
ed,s64's Avatar
ed,s64
Default Rear harness,socket bulb problem
I,ve got a new L/L rear harness installed and yesterday one of the brake lamps was out. I tried to remove it and it just dosen,t move. I know it,s supose to twist and turn out but no way.I tried to reach underneath to wiggle the pigtail but my paws to big.Question 1. Are these new lamps just a bit bigger than the socket or the sockets just that tight.2. The pigtails do they just push and turn in from the rear into the sockets.3 I guess i will have to remove the valance to make room to remove the lamp assembly and get better access to see whats up between the pigtail ,socket holder and lamp. Any sugestions. Thanks Elio
Old Oct 24, 2011 | 06:34 PM
stingrayl76's Avatar
stingrayl76
If I understand you correctly, you are trying to remove a bulb that you suspect is burnt out. You should be able to push the bulb in and twist to the left to remove.
Old Oct 24, 2011 | 07:05 PM
woodsdesign's Avatar
woodsdesign
I had the same problem in my 65 after I bought new tail light assemblies. The outboard left hand assembly had the wrong socket in it. It was the same as the inboard tail light socket. I had to file down the "tit" on the bulb so it would "comperssion fit" to make the ground.
Old Oct 24, 2011 | 08:42 PM
ed,s64's Avatar
ed,s64
Stingrayl76, the bulb won,t move at all,in,out or turn.Woodsdesign i,ll try filing down the tit on the bulb once i remove it.Does the pigtail off the harness just push and turn into the socket from the back of the housing.I ask only because the shop installed the harness. Elio
Old Oct 24, 2011 | 09:09 PM
woodsdesign
I think your problem in in the socket. I think I had to ruin the bulb when I took it out. The tit gets jammed into the socket and is not letting it turn.
Old Oct 24, 2011 | 09:33 PM
5thvet's Avatar
5thvet
The connector on the back of the tail light assembly from the harness is also a push and twist connector like the bulb ( that is the part you see when the bulb is out. If that connector was put on and not twisted right, it could give you a the problem of not lighting and also jamming the bulb. Don't know whether you can get your hand up there. You may have to remove the valence to get to it from the back. I did mine when I was replacing my gas tank so access was easy.
Don
Old Oct 24, 2011 | 10:51 PM
Pilot Dan's Avatar
Pilot Dan
Remove the bulb before you try twisting the pigtail to get it straightened out. I had a similar problem with one of my new Trim Parts tail lights, bulb was put in wrong. Removed the lens and corrected it in less than 5 minutes. Pilot Dan
Old Oct 25, 2011 | 01:57 PM
JohnZ's Avatar
JohnZ
...AND, that harness connector has two molded "****" on it that engage two slots in the bulb socket; the "****" are NOT 180* across from each other - one is offset about 160* from the other so the contacts align correctly with the contacts on the base of the bulb when correctly installed. It's possible to mis-index the harness connector and jam it into the bulb socket that way (usually shearing off one of the "****" in the process) if Bubba is involved with the installation; then usually only one contact is engaged instead of both contacts.
Old Oct 25, 2011 | 02:17 PM
1965fuelie's Avatar
1965fuelie
2018 C2 of Year Finalist
I just put new rear lights on my 67. Access is not that bad when removing the spare tire and its basket.
Old Oct 25, 2011 | 05:14 PM
ed,s64's Avatar
ed,s64
Thanks to all for your replies, the bulb is jammed and i don,t want to break it to dig out the bulb base.So i,ll do it the right way remove the valance and check each pigtail for proper install and file down the **** on the bulbs for smooth in and out removal.Do it now so next time if a bulb blows it,s a easy replacement. Thanks to all and happy fall driving. Elio
Old Oct 25, 2011 | 07:52 PM
woodsdesign
Elio,
Don't file the **** down too much. Just enough to give the bulb a tight compression fit. I came to the conclusion that Trim Parts installed the inboard socket on both tail lights. BTW my car has back up lights. Not sure if that will make a difference.
Old Oct 26, 2011 | 03:15 PM
JohnZ's Avatar
JohnZ
'63-'66 cars without backup lights (and all 67's) use the same 2-contact bulb socket (and the same 2-contact bulb) in all four lamps.
'63-'66 cars with backup lights use 2-contact bulb sockets (and bulbs) in the outboard lamps, and single-contact bulb sockets (and bulbs) in the inboard lamps.
Old Oct 26, 2011 | 05:38 PM
ed,s64's Avatar
ed,s64
My 64 has no backup lights,all sockets and bulbs the same.Came home from work and tried to remove the bulb but it,s stuck in the socket so looks like i,ll remove valance on the weekend and do it the right way. Elio
To Rear harness,socket bulb problem
