distributor bottom thrust plate?
Old Oct 25, 2011 | 04:58 AM
alexandervdr's Avatar
alexandervdr
Default distributor bottom thrust plate?
I am checking the what seems to be original distributor in my 327. There are no spacers or thrust plate between the bottom gear and housing fitted, does not seem normal. The more that the shaft/gear assembly can now move about 0.06 inch up/down. Anyone know where to get these (I do not mean the spacers between the intake manifold and the distributor)
Old Oct 25, 2011 | 07:58 AM
67*427's Avatar
67*427
Most of the Corvette parts suppliers will have the shim you need. Zip has it under part number M-2351.
Hope that helps,
Steve
Old Oct 25, 2011 | 09:06 AM
Donald #31176's Avatar
Donald #31176
http://www.summitracing.com/search/?...r%20shim&dds=1
An end play of .005" -.010" is desirable
Old Oct 25, 2011 | 10:18 AM
alexandervdr
thanks guys, really helpful.
To distributor bottom thrust plate?
