C1 power steering
St. Jude Donor '07
i can't guess at lock-to-lock, but it should be dependent on the length of the pitman arm. the major improvement will be in the ease of steering; sloppiness will depend on the condition of the mechanical joints in the front end.
Bill
Bill
In any case, in my humble opinion, someone would be better served replicating Steeroid's C1 rack & pinion setup in their backyard for roughly the same amount of effort/fabrication/cost. The R&P will provide better feel and more precise response with less linkage. How hard can it be to whip up two (frame) mounting brackets and a center link for a J-body/T-bird rack ? Certainly less than the $1200+ Steeroids quoted for just their rack & brackets with no column.
http://speeddirect.com/downloads/ins...0for%20web.pdf
St. Jude Donor '07
In any case, in my humble opinion, someone would be better served replicating Steeroid's C1 rack & pinion setup in their backyard for roughly the same amount of effort/fabrication/cost. The R&P will provide better feel and more precise response with less linkage. How hard can it be to whip up two (frame) mounting brackets and a center link for a J-car/T-bird rack ? Certainly less than the $1200+ Steeroids quoted for just their rack & brackets with no column.
too late for me to do it, but go for it...
Bill
Another option would be to buy just the steeroid brackets if you had a line on the other r&p components at a lower price. The steeroids brackets sell retail for $640 for just the brackets. They range from $100 to $160 each.
This is another power steering system that could probably be made to work since it is designed to fit the early 50's passenger cars, but mounting a pump would still pose a problem if keeping the original motor mount. Small pump with remote reservoir could be used.
http://www.ebay.com/itm/49-50-51-52-...sories&vxp=mtr
When you see the price of some of the other kits, including some rack and pinion kits, it sure makes you wonder if the $2,125 plus additional parts cost for a steeroids system is worth it. I wonder about clearance issues with the steeroids steering shaft down past the manifold and ignition shielding.
I don't know what steering box was used, but the stock
61 motor mount is gone. The Saginaw pump is mounted way
up high to clear the drag link and pitman arm. I used the round
type 2 pump in the normal spot for a power steering pump.
The F250 box and drag link under the car to the 3rd arm
worked best for me. Required a remote fill tank, but I kept the
old engine mounts.
Ray
old engine mounts.
Ray
This was my design that pre-dated the Crane add by about 3 months.
http://forums.corvetteforum.com/c1-a...-steering.html
It is a straight forward conversion, ( if you can build two simple brackets).
I have included the parts list and cost. ( Three years ago cost)
Ray
St. Jude Donor '07
Look at post #7
Ray
Ray
Bill
