storage for winter
Old Nov 7, 2011 | 04:04 PM
iluvhockey's Avatar
iluvhockey
Default storage for winter
WHat do you guys do for preparation for WInter storage. There are a lot of articles on it. My main concern is the gas tank. To leave empty as possible (I been told that that is trouble for rust. Or to keep entirely full and put gas stabilizer (but that means having gas int here for over six months).
Opinions?
Old Nov 7, 2011 | 04:18 PM
32361ARTHUR's Avatar
32361ARTHUR
Opinions?
Here in Las Vegas you can get race gas at the pump. I have some vintage motorcycles that sit for more than six months at a time without being started. I put race gas in them for the last three years and have not had one problem. I keep the tanks full. Before I used the race gas I had nothing but problems and usually had to take the carb off of each bike before it would start after a long sit. Cars are not as sensitive to the crappy gas as the bikes as the jets are bigger, but if it was mine and I knew it would sit for six months I would fill it with the 100 octane race gas. It is pricey but it works.
Old Nov 7, 2011 | 04:29 PM
stingrayl76's Avatar
stingrayl76
Filling the fuel tank helps reduce the exposed area where condensation can form and promote rust inside the tank. Fill the tank, add Stabil and drive it a few miles so the additive gets to the carb. Six months shouldn't be a problem. One good way of storing for the Winter is to put the car in a Car Jacket. Keeps moist air out.
CAR JACKET LINK
Old Nov 7, 2011 | 04:40 PM
66jack's Avatar
66jack
fill the tank and park it in garage..start it once in awhile...drive it on good days after the roads have cleared....thats it here in N. CA. they don't use salt on the roads around here...
Old Nov 7, 2011 | 04:44 PM
OldKarz's Avatar
OldKarz
From: On the bank of the Columbia River..... Washington State
Park it in my shop and drive when roads are good!
Old Nov 7, 2011 | 05:15 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I have always kept the tank full. Less room for moisture to develop. I have never used Stabil but it won't hurt, especially with 10% Ethanol which attracts moisture. I change the oil before winter and give it a good polishing. I try to find as many opportunities to drive as I can. If the roads are clear and dry I take it for a good ride. If it's going to sit all winter a good battery tender like a C-Tek 3300 is a good idea.
Old Nov 7, 2011 | 08:27 PM
Hitch's Avatar
Hitch
Not sure why so many people have problems with their cars over winter. Fill the tank and start it every couple of weeks.
Old Nov 7, 2011 | 09:20 PM
Mike Ward's Avatar
Mike Ward
I don't either, it'll be fine for six months or so. No need to start it, that can do more harm than good.
Old Nov 7, 2011 | 09:21 PM
Hitch's Avatar
Hitch
I only start mine because I drive it.. lol
Old Nov 7, 2011 | 09:34 PM
Mike Ward's Avatar
Mike Ward
That's a good thing then!
Old Nov 7, 2011 | 09:42 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Other than connecting the battery to a float charger, absolutely nothing.
Anything else is too much trouble and a waste of time.
Jim
Old Nov 7, 2011 | 09:45 PM
Hitch's Avatar
Hitch
Jim
I agree, not sure why some would add stabile and then run the car. Any fuel in the bowls will evaporate in about a week or two.
I think the biggest thing is a lot of folks have the cars parked in unheated garages that invites condensation...
Dave
Old Nov 8, 2011 | 11:56 AM
wonderful's Avatar
wonderful
I jack up my car and put it on stands, remove the tires (to stop flat spots), start the car and pour new oil in the carburator until the engine stalls, remove the battery and put it in a warm location and keep it charged, cover the car. There is no heat in my dry storage facility.
Old Nov 8, 2011 | 12:10 PM
OCS1667's Avatar
OCS1667
We lower, or take the top off in the winter. In the summer we keep the top up, and use air if you have it.
Or you can join us here this winter, as many do and bring their cars.
Dennis
Old Nov 8, 2011 | 12:18 PM
jim lockwood
My cars are parked in an unheated barn. I've never seen any evidence of condensation.... such as would manifest itself as rust formation on bare steel. Admittedly, here in CA humidity is generally low. But even when it rains/snows, though, no condensation ever.
Jim
Old Nov 8, 2011 | 01:38 PM
builder's Avatar
builder
In SD we have, regular -0 to -20 freeze, humid temps and spring thaw which creates a lot of condensation. All I do is the following:
Fill the tank and put in fuel "Stabil"izer, change oil and filter, remove battery or place a battery tender on it, place dryer sheets on top of the floor mats, and cover the car.
I drive the car enough to bring the gas level down a gallon or two (so it will not overflow if temp changes expand the gas) and to get the Stabil into the fuel system.
In the spring when there is a good thaw day, I open the doors so the breeze can help dry out the cement sweat.
When I get the car out, I put in the battery (or take off the tender) and drive the car until the tank is as empty as I dare. Then I fill it up again with 91 octane. check all fluids, lights, tires, antifreeze, grease, etc. I try to take a nice long drive (2-5 hrs) right away to help rid any condensation in the engine. I change the oil again when I park it. Usually less than 2500 miles a year.
If I park it in a heated garage, I do nothing special but a battery tender and cover.
Old Nov 9, 2011 | 10:37 AM
wonderful's Avatar
wonderful
Dennis
You lucky duck. Up north we freeze our buns in the winter. I am seriously considering your offer.
Old Nov 9, 2011 | 11:14 AM
5thvet's Avatar
5thvet
Dennis
Old Nov 9, 2011 | 10:34 PM
Hitch's Avatar
Hitch
Jim
I think that has a lot to do with where you live here in NC where humidity is a problem there is definitely condensation due to the temperature and humidity changes.
Dave
To storage for winter
