Identify M22
Old Nov 10, 2011 | 10:48 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Originally Posted by vettsplit 63
If you look closely at the angle of the teeth, and laid a straight edge at the root of one tooth on the M22, it would almost (but not quite) come out at the top of the corresponding tooth next to it, whereas on a M20/21 the straight edge would come out roughly in the middle of the tooth next to it. Clear as mud? anyway if you know what to look at it is very easy to tell.
Correct.
The tooth angles are the BIG, MAJOR difference. The M22 gears, with the lesser tooth angle, are by design much stronger--------------------but also VERY noisy. The M22 trannys make an unmistakable whine in 1-2-3 gears. Your pansy sissys don't like this whine noise-------------------I LOVE IT!
Tom Parsons
Old Nov 10, 2011 | 11:16 AM
provette67's Avatar
provette67
Originally Posted by DZAUTO
Correct.
Tom Parsons
Old Nov 10, 2011 | 11:36 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
Correct.
Tom Parsons
i like to hear a gear whine going through the gears, but am not fond of it in direct drive gears...
Bill
Old Nov 10, 2011 | 12:07 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Originally Posted by salty_waders
I see subtle differences, but is there a big difference that Im not seeing? Obviously Im not a transmission expert. just curious (in John Z's pictures).
Besides the gear teeth angle, I see the syncro rings (brass colored)are thicker and the lower shaft is much heavier as well. Good pics, thanks John, saved! Have any of the t-10?
Old Nov 10, 2011 | 01:32 PM
JohnZ's Avatar
JohnZ
All '66-up Muncies used the 1" countershaft ('63-'65 was 7/8"). Don't have any good T-10 gear photos, but they look essentially the same as M20/21 Muncie gears.
