Issues with previous burnt car?
Old Nov 12, 2011 | 10:30 PM
papisox's Avatar
papisox
Default Issues with previous burnt car?
Looking at a friend whos selling his 65 that had an engine fire last year and burnt the whole front end and interior. Is there anything I need to be extra worried about in purchasing a burnt car?
Old Nov 12, 2011 | 10:37 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
You might have trouble getting a cowl and firewall. And if the bird cage got burnt that's trashed too. Parts car. Sorry
Old Nov 12, 2011 | 10:55 PM
papisox's Avatar
papisox
Never dealt with a burnt car before, thanks for the reply. Would the heat from the fire really ruin the birdcage also? Thought it would be fairly solild with metal.
Old Nov 12, 2011 | 11:48 PM
Nowhere Man
once metal catches fire its done for. do you have pictures of the car in question.
Old Nov 13, 2011 | 12:00 AM
Hitch's Avatar
Hitch
Sorry but I have to disagree.... These cars can be rebuilt from almost nothing. So just how many midyears have YOU rebuilt? Not your Father but you?
Just because the front end was burnt that shouldn't be much worse than a front end replacement.. Just saying.. If the birdcage is in good shape carry on and rebuild it...
David
Old Nov 13, 2011 | 12:04 AM
Nowhere Man
Hitch if the firewall and cowl are burnt were would you go to get one. There not for sale all the time
Old Nov 13, 2011 | 12:08 AM
Hitch's Avatar
Hitch
The OP never said the firewall was gone only you did.
Old Nov 13, 2011 | 12:14 AM
Nowhere Man
He said the interior caught fire with it. So I only assumed that did too. I could have over stated what can be done. Any car can rebuilt with enough money
And your right I never built a mid year. Just not with my money.
Old Nov 13, 2011 | 01:17 AM
raytex's Avatar
raytex
From a donor car?
Old Nov 13, 2011 | 01:30 AM
Blk63Vette's Avatar
Blk63Vette
David
I agree with both...I seen a 427 435hp 67 Vette burn the birdcage and the cowl it was rebuilt and looked as good as new...However, that was a 427 435hp car...
Im not sure if its worth rebuilding or not...
Old Nov 13, 2011 | 01:54 AM
Vette Daddy's Avatar
Vette Daddy
Without at least pictures, no one here can accurately access what you are dealing with. Any multitude of things could be issues at this point.
Why not just buy a decent driver and go from there? Much easier and probably cheaper in the longrun.
Old Nov 13, 2011 | 02:10 AM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
You don't say if it's a coupe or rag-top. The panels will distort with the heat as well. So a new clip, wiring, everything on the firewall and engine bay, gauges, interior, straighten the birdcage, donor firewall, windshield with all hardware and stainless, possible floor reglassing, etc,etc,etc! Cheaper and less agro to buy a driver.
Unless you got it for next to nothing, with a good title.
Old Nov 13, 2011 | 02:31 AM
mike16's Avatar
mike16
I seen fibergalss burn and it gets pretty hot. without Pictures its hard to say either way but enough heat(and FG puts out more than enought heat) will change the composition of the alloy in steal,
Old Nov 13, 2011 | 05:20 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
just driving down the road one day and poof... (and no comprehensive insurance... ) fire was so hot that it turned the FI into a puddle of aluminum and softened the upper a-frames so that they just folded over the shock towers.
bought donor car and swapped firewalls, bought new upper a-frames and coil springs (no other changes to frame or suspension), new aluminum valve covers and FI unit. used rest of the engine as is (ran for 30 more years before being put out to pasture in an engine cradle in the garage... )
when finished...
it can be done, did it all myself... still have the car 30 years later
Bill
Old Nov 13, 2011 | 05:45 AM
alexandervdr's Avatar
alexandervdr
I recently acquired a 64 with 327/365hp engine. Engine was not perfect, but good enough to do some 2 minute test driving (before deciding to buy). Then, once the car at home, I decided to check the engine first. Took off air filter, started the engine, no problem. Then after some minute or so, I saw fuel pouring out of the holley carb on top of the fuel bowls, and at the accelerator pump, dripping plenty over the exhaust manifolds. Now, if I had driven the car for 10 minutes rather than 2, or if I had neglected to verify the engine, it would have been a fire for sure. I tried to restore the holley since, but finally decided to go for a brand new edelbrock. The holley is by design just too inviting for leaks to my taste. That phenomenon is even described in some C2 history books. To the holley 'believers': I am not saying it can not be made leak free, nor that it is a bad carb, just that the design of the side bowls and bottom pump with gaskets is a risk area.
Old Nov 13, 2011 | 06:35 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Bill - I don't know of many that would have tackled rebuilding your '62 after looking at your first two post-fire pictures. It looks like a terrorist attack. Good on ya fella.
BTW - any carb can leak if not properly installed and maintained...my "professionally" restored dual quad Carters started an engine fire a week after I got them off eBay due to faulty assembly.
Old Nov 13, 2011 | 07:40 AM
DansYellow66's Avatar
DansYellow66
Yes - are you mechanically and body work inclined/experienced and a do-it-yourselfer? If no, then be very worried. That isn't something you can farm out to a restoration shop unless it's a very rare car or you are related closely to the Sam Walton clan.
To Issues with previous burnt car?
Old Nov 13, 2011 | 09:17 AM
erb64's Avatar
erb64
when finished...
Bill
did you buy insurance for the rebuilt car?
Old Nov 13, 2011 | 09:20 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
yep, i was 'richer', and smarter, then..
Bill
Old Nov 13, 2011 | 09:42 AM
papisox's Avatar
papisox
Thanks guys, I'll try to get some pics. Price would be around $4000. I figured frame and title would be worth that alone. It was/is a numbers matching car, shame to let it be scrapped or parted out.
