Bell Housing
The bellhousings that take the larger stud which screws in from the transmission side were NOT unique to Corvettes. ALL hi-perf passenger car applications also used this bellhousing (at least in '57....)
Jim
Jim
The thing I am always leery about with the '60 - '63 aluminum bell h'sg is how much deflection sag must occur due to the awful way GM decided to mount the motor.
I feel (without digging into my old school books) that the aluminum stretches more than Cast Iron and consequently impacts transmission / input shaft alignment and wear.
Also can the '58 & '59 owners please confirm that their cast iron bell housings DON'T have side mounts ?
I am really having a hard time with that one ?!
Because other knowledgeable folks have said that they lost the side mounts after '57 ?
And I really don't think GM moved the stud location so it was easier to replace.
When did anyone change a design to make seldom required operation easier ?? - it's probably easier to replace inside the housing anyway.
The balance of the 1962 Chevrolet model lineup (except 409) kept the old Blue Flame 6 cylinder as standard, the cast iron bellhousing, large flywheel and large front bearing retainer.
Starting in 1963, the "new" aluminum bellhousing was integreted into the full size carline and Corvette along with the 154 tooth flywheel, small bearing retainer and block mounted starter, across the board. In 1963, Pass car also received the new 6 cylinder engine that had a block bellhousing bolt patter like the existing V-8 so now, all bellhousings are common except 409.
In order to commonize machining operations, all these bellhousings were machined for the carryover small bearing retainer. That included Chevy II, Corvette, and Pass car, except 409.
The following model year, all those product lines switched back to the larger front bearing retainer. If my memory is correct, I think there were durability problems with the small front bearing in use behind 327 engines and the decision was made to upgrade to the former size across the board. Again, to commonize machining.
Now you know the rest of the story.
Did I say it right that time?
Tom Parsons
I've never taken one apart to measure/count the ball bearings in the front race, but I guess there might be (maybe) one more bearing in the 4 11/16 large bearing. Interesting!
The bearings with 11 and 12 are commonly referred to as "max" bearings. I buy ALLLLLLLLLLL my 4sp parts from Larry Fischer of D&L Transmission and his rebuild kits always include the max front bearing.
Tom Parsons
Jerry
The truck bell housing was VERY similar (but NOT identical) to the car/Vette housing. The mount pads on truck housings had a single threaded hole and the second hole had a pointed locating pin. Trucks used the side mounts up until about 1970.
For you guys who need to know some minor differences in early bell housings, here is a comparrison between a pass car (Vette) and truck bell housing. Often times at swap meets I've seen inscrupulous or unknowing sellers trying to pass off a truck housing as a 55-57 (or 59 Vette) housing.
For an early Vette, a truck housing (as pictured above) would FUNCTION perfectly, but of course would not be "correct". If a person were in a bind to get their car together and a truck housing was all that was available at the time, it could be used as an interim housing until a correct one could be located.
Tom Parsons
