C2 Head lights
Old Nov 26, 2011 | 03:22 PM
waverider62's Avatar
waverider62
Cruising
Default C2 Head lights
Hello I have a question maybe someone on here can answer. When you pull the headlight switch are the lights supposed to roll up? I have the hardware to replace the switch and want to make sure that it is wired right. Thanks in advance.
Old Nov 26, 2011 | 03:25 PM
erb64's Avatar
erb64
not at all the rocker switch for the headlight doors are below the pullout ****. Screwed into the underside of the dash.
Old Nov 26, 2011 | 03:31 PM
TC233's Avatar
TC233
CF Senior Fox Bat
No, the light should shine on the road first then as it swings around, on the road. So the rotation is clockwise when on the drivers side looking across your hood. If the lights rolled up and the the light came on early you would end up blinding yourself
Old Nov 26, 2011 | 03:34 PM
62Jeff's Avatar
62Jeff
As stated, pulling the headlight switch simply turns on the headlights. In order to roll the buckets up or down, you have to use the addition switch mounted below the instrument cluster on the left side.
Old Nov 26, 2011 | 03:41 PM
waverider62
Cruising
Thanks for the help
Old Nov 26, 2011 | 03:44 PM
TC233's Avatar
TC233
CF Senior Fox Bat
Thought he was asking which way the buckets rotated? Now I'm not sure what he was asking
Old Nov 26, 2011 | 04:04 PM
vt65's Avatar
vt65
well in later years beginning with 1968 the headlight opening is activated by the headlight switch so turning the headlights on also opened the doors, we just happen to drive the more antique automobiles that every function has to be done separately ....
Old Nov 26, 2011 | 04:10 PM
erb64's Avatar
erb64
must be a Canada thing??
Old Nov 26, 2011 | 04:14 PM
vt65's Avatar
vt65
nope, they were all made in the USA
now the new Camaro's we make them and the headlights stay on all the time ..
Old Nov 26, 2011 | 11:24 PM
RestoMike's Avatar
RestoMike
From: Livin' large and havin' fun in wonderful Oklahoma
No.......I'm think'n it's more of a retirement thing
Old Nov 27, 2011 | 09:59 AM
TC233's Avatar
TC233
CF Senior Fox Bat
When brain farts collect, instead of being released occasionally, you can have a massive blow out all at once, I experienced such an event with this question
Old Nov 27, 2011 | 10:07 AM
RestoMike's Avatar
RestoMike
Purge yourself brother! Don't let the pressure build up.
btw.....don't think for for minute it hasn't happend to the rest of us!
To C2 Head lights
