Engine mount shim
Old Dec 5, 2011 | 10:25 AM
KNIPPS's Avatar
KNIPPS
Default Engine mount shim
I posted this a while ago but didn't get any response...as I get closer to the body drop I want to make sure I do not have a problem as any problem will be much easier to deal with, with the body off. I have the trans in and it seems to be ok. I have not yet installed the drive shaft...thanks....
earlier post:
"I got the engine in last night but it didn't happen without a little bit of an issue. I had to shim the passengerside motor mount inorder to get the bolt through. Should this be a concern? I used a "V" type shim that I guess was used on 427's with a/c. the hole was only off by about 1/16 or 1/8. I am guess in the mounts might have been off but I wanted to check with the "minds" and make sure I am not overlooking a bigger issue before I bolt up the trans...Thanks...Jim"
Old Dec 5, 2011 | 10:31 AM
62Jeff's Avatar
62Jeff
Jim I can't help with an answer, but from looking at your post I'm guessing:
1) You have a 63 through 67 corvette based on reference to passenger side motor mount.
2) Your engine is a 427, which implies maybe you have a 66-67
More details may help the forum know how to respond
Old Dec 5, 2011 | 10:44 AM
KNIPPS's Avatar
KNIPPS
Default more info
Sorry,...it is a 67 originally a 427/390...replaced with a 72 bb...the mounts that came off the old engine were pretty trashed and they were replaced with correct mounts for a 67...the blocks should be the same so I am not sure why I ran into this problem...maybe just the mount design??..thanks ..Jim
Old Dec 5, 2011 | 11:01 AM
66jack's Avatar
66jack
Did you get the correct Motor mounts?
Aren't the BB/SB mounts different?
Old Dec 5, 2011 | 12:08 PM
MikeM's Avatar
MikeM
A shim to mount the engine should not be required. A 1/16" or 1/8" of misalignment to get the through bolt to align is well within the realm of using a drift pin to align the frame/mount. Ideally, that shouldn't be required either.
Either way, whether you drift the holes on location or used a shim of no more dimension than you describe, I wouldn't worry too much about it.
Are you using the pointed through bolts or hardware store blunt end bolts?
Old Dec 5, 2011 | 12:25 PM
KNIPPS's Avatar
KNIPPS
Default bolts
I believe the bolts have a little taper to the end...It has been a while since I installed the engine...April I think...anyways I was just concerned there might be a bigger issue..The only thing I could think of would be the engine mounts themselves...the frame is the same (powdercoated now) but the same...the block allbeit a different one should be the same..the only different factor I came up with is the mounts...time will tell I guess....just hope it all doesn't blow up once its together...Jim
Old Dec 5, 2011 | 12:28 PM
KNIPPS's Avatar
KNIPPS
Default shim
I am bothered by the fact I had to use a shim...I want everything to go back together the way it came apart...just paranoid thinking something major is wrong!!!
Old Dec 5, 2011 | 02:55 PM
fullcontrol's Avatar
fullcontrol
Paid Senior Member
A/C Big Blocks require shim. Available at Corvette Central or ebay.
MOTOR MOUNT SHIM - 427 WITH AIR CONDITIONING - 1 REQUIRED
Mounts between engine block and motor mount to keep carb floats level.
http://www.ebay.com/itm/1966-1974-Co...#ht_1205wt_736
Old Dec 5, 2011 | 03:59 PM
MikeM's Avatar
MikeM
He is shimming to get his motor mount bolts in, not to keep his floats level. That shouldn't be required to install the bolts. Still, the OP needs something else to worry about.
Old Dec 5, 2011 | 04:54 PM
KNIPPS's Avatar
KNIPPS
Default Yikes!!
Old Dec 5, 2011 | 05:17 PM
mark6669's Avatar
mark6669
I have seen midyear big block cars with sagging front crossmembers when doing front end alignment this sounds like the same problem measure between upper control arm mounting flanges workshop manual does not have a spec. for this you have to measure another car.
Mark Napoli
Old Dec 6, 2011 | 01:57 AM
buns's Avatar
buns
Most roads are banked towards the ditch for water runoff. Lots of roads run uphill and/or downhill. Some guys drive rock crawlers at an almost vertical angle. Can't see how a shim would help in these situations.
Plus, the earth is round ( so I'm told ). So you are never driving on a flat surface.
Old Dec 6, 2011 | 06:21 AM
MikeM's Avatar
MikeM
Mark Napoli
Now you're gonna' get him excited!
Old Dec 6, 2011 | 05:44 PM
JohnZ's Avatar
JohnZ
MOTOR MOUNT SHIM - 427 WITH AIR CONDITIONING - 1 REQUIREDMounts between engine block and motor mount to keep carb floats level.
Actually, it's two - the shim was used on both sides.
To Engine mount shim
