58 engine/trans mount help please
and i can't see how you could screw up the front motor mounts as you are using the stock water pump mount type.
the important criteria is u-joint angle to prevent vibration. your u-joint/driveshaft angle should improve once you get the weight of the body, etc on the frame.
Bill
Another observation.
The bolts you have used for the crossmember to the frame may be too long. Those 4 bolts sticking up about 3/4" above the nut. I believe they will hit the body when you put the body back on. With the body on the car, there isn't much room there.
Pilot DanOne other thing I noticed (but you did not ask about) is the Generator adjusting bracket is on the wrong side on the end frame. It should be on the other side with the bolt pointing forward.
Pilot DanBill
Tom Parsons
but, Bubba Bill (me) would fix it for less than $2 by spacing the crossmember down using 4 nuts that slide over the bolts that mount the crossmember to the frame. although he didn't use nuts, Tom Parsons has spaced his down too.
his call... both ways will fix it...
Bubba
Bubba
http://www.parts123.com/parts123/yb....Z5Z5Z50000050x
Whether it be an original B-W T-10 mount setup, a 62 style (as in the above pictures), or a Muncie with a 62 tranny mount plate-------------------------THE REAR OF THE TRANNY NEEDS TO COME DOWN. The factory original mount on the T-10 housings was STILL TOO HIGH. Consequently, the U-joint angles on 57-61 stock 4sp setups are too severe and the 62 with the adapter plate is even worse.
I have a Muncie in the 56 with a Hurst shifter and a REPLICA 56-58 shifter handle bolted to the Hurst shifter.
As can be seen below, I use the 62 (ONE YEAR ONLY) style tranny mount adapter plate for the Muncie, plus, I've installed 1in square tubing between the frame X-member and the tranny cross member. This was very strongly recommended MANY years ago when installing a Muncie in the early chassis became popular.
The dual mount bosses on the B-W T-10 first occured about 60-61 to accomodate a change in the full size pass car tranny mount setup, but it remained the same for Corvettes through 61. Then, in 62, that adapter plate was used for the Vettes. ALSO, the 62 ONLY Vettes----------------FROM THE FACTORY-----------had spacers installed between the frame X-member and the tranny cross member (they were about 1/8in thick)-----------------------BUT THEY STILL DID NOT LOWER THE TRANNY ENOUGH!!!!!
Sooooooooooooo, since you have the 62 style mount setup, I would strongly encourage you to lower the rear of your T-10 by either installing the correct style 56-61 style tranny mount to the REAR mount boss and also fabricate some spacers to go between the frame X-member and tranny cross member, OR, leave your setup up as it is now and just add spacers between the frame X-member and the tranny cross member.
Either way, the rear of your tranny should go down.
YA, YA, YA, YA, YA, YA, YA, I know, the NCRS types are going to say that is NOT how it came from the factory---------------and that is correct. But less stress will be imparted on the U-joints if the tranny is lowered. Your choice!
Tom Parsons
Pilot DanThat "Muncie 4 Spd adapter plate" to which you refer was indeed used to install Muncies in C1s. But it was also used by Chevrolet as a factory part to install T10s in 1962 Corvettes. It can be used as Waffle uses it in the photos in his 1958. The correct 1958 part will use the rearmost 2 holes as Pilot Dan says.
But none of this should make any difference. Waffle wants to get the transmission as low as possible in order to make the angle of the driveshaft as small as possible. Whatever does that is to the good.
Yeah, the correct part is so cheap, I'd probably use it too. But that's because I'm NCRS-matching-numbers-nuts. Nobody's ever going to see down there once the body is on.
I believe the correct 1958 part will raise the transmission slightly, which means the crossmember mount will need to be dropped more.
(P.S. as a public service I will be changing my avatar)
Bill
