Differential question.
Old Dec 14, 2011 | 01:22 PM
raypilot65's Avatar
raypilot65
Default Differential question.
A while back I was investigating some numbers on my car, which is a 65 Convertible. I have the original transmission, but after posting the following numbers off the differential D 11 4 78 1 , John Z thought it was a 79 differential, but that the D should be two letters. I went back under, cleaned the area, and had a magnifying glass, but it still looks like a "D", so I can't tell from that what the ratio is. The car seemed to me to be somewhere between a 3:70 to 4:11. It runs just under 3000RPM @ 60MPH. This morning I jacked her up and turned the wheel and counted the revolutions of the drive shaft and it loooks like about 3.3 or a 3:36. Could they have change the rear end to a higher gear and not changed the speedometer gear so that I am going much faster than I think, or do you think something else is wrong like the tach or speedometer. When I get a chance I'll have the wife follow me in her car . Tires are stock size 205 75R 15.
Old Dec 14, 2011 | 01:26 PM
66jack's Avatar
66jack
Anythings possible
If you have a GPS.it should have a mph somewhere on it to check
Old Dec 14, 2011 | 01:37 PM
rustylugnuts's Avatar
rustylugnuts
Try this: http://www.chrismans.com/Calculators.html
rustylugnuts
To Differential question.
