just removed my locks from the doors on my '65 and got them freed up, problem is my ignition key does not work in them. I got a number from the cylinder cover so can it be used to cut new keys? Is there someone who can do this if I give them that # or do I need to get a whole new set of locks from a supplier like CC? I see they have a set of replacements listed for $89 but i'd like to keep my originals if possible. Has anyone used the replacements and do they work ok? Went to the local GM dealers and they don't cut keys from that era, their machine only goes back to '67 and the key machine did not recognize my code
Corrected: As 5thvet pointed out below, the ignition and doors are the same. You should be able to find an older locksmith shop to cut keys to match the doors. I'm not sure if the door cylinders can be changed to match the key you have, maybe someone who has done it will help here.
yes I agree guys but locksmithing seems to be a dying vocation in these parts anyways, my shop manual shows only 1 key for all jobs for 1965 but i thought they used 2 different ones till now.
Your ignition key should work the ignition and both doors. The round key is for the glove box and spare tire lock.
Contact Pete Lindahl in New Mexico.
He is the man for this kind of key smithing.
He will sort it all out for you,
write him at pclindahl@comcast.net
please tell him Don in LA referred,
Pat specializes in old Chevrolet locks and lock sets. He has all the old codes, as well as the correct key blanks. Pat supplies the lock sets that are sold by all of the Corvette vendors.
Call him with your codes, and he should be able to fix you up. 1-410-879-9647.
We have a real mccoy, old school locksmith shop right down the street from me. If you want to bring your cylinders up to the big smoke then PM me and I'll give you their details.
I have all the code books and the machine to cut them...I understand that the numbers on the cylinders is the code needed to properly cut the keys.....give me the numbers and I can give you the 6 number cuts needed without sending your keys anywhere....All you would need is to give those numbers to a local dealer and have them cut ....the blanks are 'B-10 and B-11.....the year is necessary too
Pete did a SUPER job on my 67. When I got the 67 all my locks were screwed up, "A" key fit in the "B" keyway and vise versa. I sent him all my locks (ignition, glove box, door, spare tire) and he reworked them all sent me the correct "A" and "B" Briggs keys with knockouts and they all worked like new. Plus Pete is VERY VERY reasonable!!
Actually what you ideally want to do is have the door locks re coded to match the ignition lock or get a key off the door lock code and re key the ignition. Either way, 1 key to work both would be preferable. You can of course just get a key to fit the door locks (assuming they are both the same) if you don't mind an extra key. I had several re keyed to all match and I think it cost me $10-15 per lock a few years back. Local guy with the Briggs and Stratton box. Pilot Dan
Another vote for Pat Kraus.
He actually makes the locks sold by most if not all of the catalog companies.
Tell him I said "HI".
"The Kraus" is a great guy. He was my neighbor for 35 years back in Fallston, Maryland.
I agree, any competent locksmith should have the code sheets for GM locks. Just take them the code off the lock and they can cut you a new one. The locks are a snap to re-combinate as well. The little wafers are easily removed and replaced to match one lock cylinder to another.
All Early GM locks used the same wafer segments, and I keep a selection in my shop at all times to re-key cylinders.
