Headlight bucket
CF Senior Fox Bat
Headlight bucket
If I want to remove the entire Headlight bucket from the car 63), can the entire motor assembly and gear box be removed all at once or must you remove, motor, then remove other pieces one at a time before pulling the bucket?
It feels like the only thing holding the entire assembly into the bucket is the point where the gear box enters the bucket at the moment.
I have the motor support disconnected, the three screws that hold the gear box to the side of the bucket through the frame loose, or removed, is there anything else? The motor was taken to the point where it dragged and backed off 6 turns. So I can remove motor separately I was just hoping the whole assembly can be removed at once?
CF Senior Fox Bat
Got the answer- motor first
Then the Y piece which is bolt compressed around the shaft
Then the last portion which includes the shaft, the ball and the cup that goes into the inboard side of the headlight bucket
CF Senior Fox Bat
Got it done. I swear to god whoever worked on this car before I got it, had a commercial license for anti-seize. Even the header bolts came out with ease. This is such a treat to work on. I am used to using 40 cans of WD40 on a simple job up here in "Rusta-popolis". 48 year old Arizona Car, its truly unbelievable.
Good Luck
CF Senior Fox Bat
I have put it back in twice today just to ensure that I know exactly how things go. The next time the bucket goes in, it will be repainted so have to get the process down pat.
