64 Muncie date code
Old Dec 30, 2011 | 04:41 PM
vettjam's Avatar
vettjam
Default 64 Muncie date code
Did the 1964 Muncie 4 speed have a date code on the case? All I can find is the numbers 4115281 that indicate it came out of a 1964 with VIN # 115281.
Thanks for the input.
Old Dec 30, 2011 | 04:55 PM
1snake's Avatar
1snake
On the opposite side of the main case from where the serial number is stamped, there should be a date stamped. Here's mine on my 65.
Jim
Old Dec 30, 2011 | 05:18 PM
vettjam's Avatar
vettjam
Just took a close look at that spot and there is nothing stamped there.
Old Dec 30, 2011 | 11:31 PM
DrainSurgeon77's Avatar
DrainSurgeon77
1964 Muncie had the build code on the lower RH corner of the machined surface the side cover bolts to...
Hope this helps... Crash
Old Dec 31, 2011 | 11:03 AM
vettjam's Avatar
vettjam
Crash,
Right where you said it would be.
I assume this is March 31, 1964?? What does the little 3 in the square designate?
Old Dec 31, 2011 | 05:17 PM
DrainSurgeon77
Thats the code for the assembler, any problems trace back to him/her...
Old Dec 31, 2011 | 07:41 PM
jimgessner's Avatar
jimgessner
Originally Posted by vettjam
Crash,
The neat thing about this is the date should fit the engine assembly date as well. If you have the original engine I would bet it is stamped F0331xx or close
To 64 Muncie date code
