65 side pipe
Old Jan 1, 2012 | 09:55 AM
carlisle61's Avatar
carlisle61
Default 65 side pipe
I'm installing side pipes on a 65 that did not have them originally. Do I need to remove the small tabs that are located along the side of the car below the doors, or can I just leave them?
Old Jan 1, 2012 | 10:00 AM
Geralds57's Avatar
Geralds57
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Originally they were cut off on a sidepipe car. It won't hurt to leave them, and if you decide to remove the sidepipes, you'll still have the tabs. There was also a radius cut out of the inner fender well shield also behind the exhaust tip. I don't know how it would look, but you could Black out the tabs so they wouldn't be as visible. Look at your trim tag and see if it was an "S" or "A" body. AO Smith bodies did not come with sidepipes. Just something to think about. Personally I love the sidepipes.
Old Jan 1, 2012 | 10:22 AM
Mike Geary's Avatar
Mike Geary
My coupe has owner-added sidepipes ('65). The front body tabs have to come off, but the rears don't interfere and don't get hot from the exhaust.
The metal rocker brackets - it's much neater to cut them off than just bend them back (which will work). But leave about 1/2" stub exposed.
Makes it easier to go back by welding new bracket sections back on.
Old Jan 1, 2012 | 11:32 AM
Dicecal's Avatar
Dicecal
Thats the way I did it on my 65 Coupe.
Old Jan 1, 2012 | 11:40 AM
provette67's Avatar
provette67
the front tabs do not need to come off but it does look better.Here is a coupe that had pipes added with the tabs left in place.
Old Jan 1, 2012 | 12:08 PM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
I am not sure that this is correct. If that was the case you would be able to see the evidence of it. On my car (which is an original side pipe car) I don't see anywhere that it had the rocker moulding hangers on it and were cut off. Also, if that was the case you would never be able to tell if the car was not a side pipe unit. Any St Louis built body could be considered correct, even under NCRS guidelines.
Old Jan 1, 2012 | 12:16 PM
TheSaint's Avatar
TheSaint
Perhaps the factory side pies car did not have the tabs at all?
If it was my car an i was going to add sidepipes i would not cut off the tabs
If i had to bend the tabs i would bend them as little as possible
Old Jan 1, 2012 | 12:28 PM
Geralds57's Avatar
Geralds57
The sidepipe frame was different also, in that it had the holes for the pipe hanger brackets were punched into the frame for the pipes, but only in St. Louis. A non sidepipe car will not have the punched holes. They can't be duplicated.
Old Jan 1, 2012 | 12:33 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You'll find all the pages from the AIM for installing side exhaust at this link. There are also some other bits of info on there too.
http://willcoxcorvette.com/repairand...lp.php?hID=327
Old Jan 1, 2012 | 02:18 PM
JohnZ's Avatar
JohnZ
Actually, there was no difference in the frame - all of them had the "keyhole" at the rear of the side rail for the rear pipe hanger carriage bolt.
Also, the rocker molding support brackets on the birdcage sill weren't cut off on an original sidepipe car - they were never welded on to begin with.
Old Jan 1, 2012 | 03:19 PM
TheSaint's Avatar
TheSaint
If the tabs is left in place or cut off i suppose that there is no way you can see any difference except from under the car and the front on the fenders which i would never cut off to add sidepipes?
Old Jan 1, 2012 | 03:20 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Originally Posted by TheSaint
If the tabs is left in place or cut off i suppose that there is no way you can see any difference except from under the car?
there are plenty to look at if you know what you are looking for.
Old Jan 1, 2012 | 04:02 PM
TheSaint's Avatar
TheSaint
I am sure there is but for me it looks like the lower front of the fender in front of the side pipe is the only thing i can tell is wrong on the picture above
Old Jan 1, 2012 | 04:04 PM
Nowhere Man
yes from that view
Old Jan 1, 2012 | 04:10 PM
macs65's Avatar
macs65
My 65 is an A.O. Smith bodied car, When I installed the side pipes they were a very easy install, I did not have to cut or remove anything. I do not have that little fender tab at the front of the pipe. I guess someone may have had the pipes on before and removed them before I bought the car
Old Jan 1, 2012 | 04:29 PM
Geralds57's Avatar
Geralds57
Thanks John, I stand corrected.
To 65 side pipe
