67 fuel pump brass fitting
Old Jan 6, 2012 | 11:51 PM
emdoller's Avatar
emdoller
Default 67 fuel pump brass fitting
I just received a brass fitting for my rebuilt fuel pump that I ordered from LIC. I have a L79. I tried screwing it in by hand and it went in about 3/4 of a turn. I grabbed a wrench and tried tightening it and it felt pretty hard so I stopped. From what I could tel,l getting it all the way in felt like it would be pretty tough if not impossible but I'm not sure. I just dint think it should be that hard.
How hard should it be?
Also, I'm assuming I shouldn't be using and Teflon tape or dope as that would only make it worse.
When I takes the old one off tomorrow I can try te one on the old pump.
Thoughts?
Ed
Old Jan 7, 2012 | 03:29 AM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
There's at least 2 different size inlet/outlet lines, so just wait to get yours off and side by side before you force anything. They may have sent the wrong one, or the wrong fitting!
Old Jan 7, 2012 | 08:33 AM
66since71's Avatar
66since71
I'm almost embarrassed to ask, but is it pipe thread? If so, it's supposed to behave as you've described... And there will be no hard "bottom". Alternately, if you only got a turn or so, you may be forcing a pipe thread into an inverted flare. Google inverted flare for a pic..
Harry
Old Jan 7, 2012 | 08:57 AM
emdoller's Avatar
emdoller
Harry
Not sure. I'll post a picture later.
Old Jan 7, 2012 | 09:37 AM
emdoller's Avatar
emdoller
Here are pictures of the fitting and the pump. Not sure what type of fitting this is called but maybe the connector isn't right. I purchased it here (see photo at bottom of page):
http://www.licorvette.com/fuel_line_set_corvette.htm
Ed
Old Jan 7, 2012 | 10:01 AM
Ironcross's Avatar
Ironcross
you should have gone to a GOOD local parts store like I suggested....but the fitting you purchased is a pipe thread .....its unclear what the pump will take however it could be an inverted flare style as GM pumps offer both depending on the year.....What is on your OE line leading from the pump to the carb?....it should be an inverted flare from the factory as OE would be a hard line and not a hose fitting.....the flexible hose line is between the pump and frame/tank'
Old Jan 7, 2012 | 10:09 AM
emdoller's Avatar
emdoller
I went to 2 local auto parts stores and they hand nothing like this. You are correct in that this is the fitting that connects to a rubber hose and then to a metal line that goes to the tank. The line that goes from the pump to the carb is a flare and hard line that seems to fit just fine.
Old Jan 7, 2012 | 10:56 AM
Bill32's Avatar
Bill32
Something's wrong with the threads/thread style match. It's hard to tell from the pics.
I just walked into the shop and looked at my original. The hose fitting should screw into square fitting on the pump far enough that there is only a 1/8th gap between the two square parts.
The threads on the pump fitting look a bit questionable on the right side of the hole but again, it's hard to tell from that pic.
You certainly don't want to force it in any further.
Old Jan 7, 2012 | 11:39 AM
emdoller's Avatar
emdoller
Thanks. I need to run to the auto parts site because my next step is to remove the old pump which means I need to come up with something I can put on the end of the rubber hose to keep the tank from draining onto my garage floor!
Once I do that, I'll be able to look at the fitting on the current pump.
Ed
Old Jan 7, 2012 | 01:13 PM
QIK59's Avatar
QIK59
Ed
Sounds like you you've got in pretty deep here ; major saga to follow LOL
Old Jan 7, 2012 | 02:28 PM
emdoller's Avatar
emdoller
You've got that right ESPECIALLY when you consider the pump works!! The only reason I'm swapping it out is because I'm putting the original carb on and noticed that the previous owner put a coupler between the fuel pump and the hard fuel line which pushed the fuel line into the radiator house.
Anyway, I'll take off the line later today and see if the piece on the current pump fits my new one.
Ed
Old Jan 7, 2012 | 03:32 PM
emdoller's Avatar
emdoller
Originally Posted by Kerrmudgeon
This is wrong in a lot of ways, and just plain ugly! It's set up for a rubber gas line which is not a good idea and bubba to boot, the braided original is much stronger and has the proper fitting on the end of it, that second elbow is pipe thread going into a compression flare type fitting, and that's totally the wrong style pump (much later) for the car. You may even have clearance problems trying to fit it. Do it once, do it right!
You should have left the old pump alone if it was working well, IMHO.
A couple of things:
1) This is the correct pump for a 67 L79
2) The original setup on a 67 L79 is to have this style connector with a rubber hose that connects to the metal line that goes back to the tank,
3) The set up that was on the car (original pump as described) had the outlet stripped so it contained a spacer so that the metal line that went between the pump and the carb was pushing into the water pump house - not too good.
Old Jan 7, 2012 | 03:37 PM
emdoller's Avatar
emdoller
Ok, just took off the old fuel pump. wasn't too bad to take off but getting it back on isn't going to be fun.
Here's a picture comparing the inlet adapter that was on the car to the one I purchased form LIC. The good news is the old one fits nicely into the pump so I should be good to go.
I have a couple of questions:
1) When I took the pump off the push rod slid down... How do I get it back up? I tied with my hand it I can't seem to move it and it seems like it's all the way down. Do I need to remove the plate (2 screws) to get to the bottom of it?
2) I thought I read that I could remove the bolt that's on the from of the engine block and insert a longer one to hold that rod while the pump is installed... is that right? is it the on right on the front of the block? How long of a bolt should I use?
Thanks!!
Ed
Old Jan 7, 2012 | 04:04 PM
Kerrmudgeon
Opps, sorry about that. I assumed stuff I shouldn't have. I thought those closed units came out in 68. Apologies.
Old Jan 7, 2012 | 04:14 PM
emdoller's Avatar
emdoller
No problem!! I agree they are ugly!!
Ed
Old Jan 7, 2012 | 05:06 PM
Tom Austin's Avatar
Tom Austin
ED,
YES - take the plate off so you can pull the push rod out. When it's out, stick one end in a tub of grease - and push that end in the engine - the grease will hold it in place until you get the pate and pump back on!
Tom
Old Jan 7, 2012 | 05:54 PM
emdoller's Avatar
emdoller
Thanks! Heading back to the auto parts store for the gasket.
To 67 fuel pump brass fitting
Old Jan 7, 2012 | 06:26 PM
Ironcross's Avatar
Ironcross
I don't think you need to remove the plate...there should be a plug that the push rod is inserted by...remove the plug, grease the rod and put everything back togethert
Old Jan 7, 2012 | 07:03 PM
JohnZ's Avatar
JohnZ
No plug on a small-block; only on a big-block.
Old Jan 7, 2012 | 07:10 PM
JohnZ's Avatar
JohnZ
Thanks!!
Ed
1. If you can't move the rod, take the plate off.
2. A 1-1/2"-long 3/8"-16 bolt will work fine; be sure to remove it and replace the 1/2"-long original bolt before you start the engine.
