Rear end help needed?
Thanks in Advance
Thanks in Advance
I am going to jump in here before Tom gives you his sermon from a higher level of intelligence LOL .
You can NOT simply bolt a 3.36 gear set to your 4.11 posi carrier.
Carriers USUALLY come in families based on ratio series.
For C1's :
The 4 series carriers will ONLY work with 4.11 4.56 etc gear sets.
The 3 series carriers are required for 3.08 , 3.36 , 3.55 , 3.70 or 3.73 gear sets (I am sure some know it all will be all over me "there never was a 3.73 ratio !" - there are and I have some !)
There were some special gears made (now discontinued and now forgotten by me due to irrelevance) that I believe allowed you to run 4.11's and possibly 3.70's on the opposite carrier (had to cover that as if I didn't someone else would LOL)
There are no 3.23 gears for C1's
I don't know if there are any new (aftermarket) 3.36 gears available.
But they are a pretty common ratio available used at swap meets etc - I regularily pass them up.
Correction : Tom (below) lists 3.36's from US Gear
Contact Tom Watt at Tom's Differential's in Idaho he will have the proper Posi carrier that you need and can probably supply the gear set to match.
TOM KNOWS HIS STUFF - I have dealt with him for approximately 25 years.
I do not have Tom's current phone number since he moved from California where I used to deal with him.
Just Google Tom's Differential's and you'll be able to find his contact info there - I recently did but misplaced the #.
THIS IS THE DEFINITIVE AND ACCURATE INFO you asked for BECAUSE I KNOW from actual experience
.Jerry
They had the best prices. I took my 4.11's out of my 60 and using Tom's tutorial, built a 3.70 posi unit out of a old 3rd member I had laying around.
It had 3.36 ring and pinion that are in perfect cond. Let me know if you're interested in the gears.
Jim
No problem with the earlier style pumpkins.
Jim
I just quickly checked a couple of early Posi units I have - which I assumed (hope) are 3 series and the dimension from the ring gear flange to the centers of the spider shafts was ~ 1 5/8".
DOUBLE CHECK YOUR MEASUREMENT THERE ?
BUT THE BIGGIE : I also had a quick check through some of my rear end catalogues and the in the US Gear / Strange catalogue found part number 01-884411 for the "trick" 4.11 gear set ( for use on a 3 series carrier) !
Sooo looks like all you MIGHT need is the 3.36 gear set !
Bill
