........they'll get MUCH more on a fastener than you'll ever get beating it with a hammer.
Originally Posted by MikeM
That would depend on the weight of the hammer and the enertia behind it, wouldn't it?
Well, I think the correct answer would be both yes and no . . . . theoretically it would depend upon the hammer, the inertia, the material both the hammer and the spinner were made from, probably other factors, I suppose.
But practically speaking, manually operated gear drive torque multipliers are available that put several thousands of pounds of torque on a fastener. I'm guessing you'll not be able to pick up the hammer that would match their capacity, much less be able to swing it to beat on the spinner . . .
I'd agree with that but we were talking about a fastener that requires only 450 lb ft of torque and that should be easily achievable with either a long handled wrench or the proper size hammer with the proper enertia behind the blow!
