59 Windshield Post Stud Metalurgy Question
Old Jan 14, 2012 | 02:06 PM
Workin On 59's Avatar
Workin On 59
Default 59 Windshield Post Stud Metalurgy Question
I got the three 5/16 inch studs out of my windshield posts that were too short(only one of the four studs was long enough). Now I need to replace those three short studs with ones of adequate length.
I have 5/16 inch galvanized carriage bolts that I can cut down to the right length, clean the threads up and install the new front studs with loctite so they won't screw into the glass.
Question is this: Are the galvanized bolts compatable with the windshield post metal or should I try to get stainless steel or some other metal stud? I am guessing that loctite will also work ok on galvanized studs. I do have SS nuts to go on the galvanized studs.
Thanks, Doug
Old Jan 14, 2012 | 02:24 PM
UberLegend's Avatar
UberLegend
Good question.
Old Jan 14, 2012 | 03:04 PM
Plasticman's Avatar
Plasticman
The primary metal in the door post (which are pot metal) would be zinc (along with various other metals), which is also what is used for the galvanizing on your bolts. Would be no issue using them.
The use of Loctite will prevent any moisture from creeping up the threads in any situation (acts as a thread sealer), and is a good idea to lock the studs in place.
There is possible concern with the use of SS nuts on galvanized (zinc) steel only in areas that see lots of moisture. But it should not be a concern in this application.
Plasticman
Old Jan 14, 2012 | 09:22 PM
Workin On 59
That makes sense, plasticman.....I wondered if the posts were made of potmetal. That's definitely what it looks like inside the threaded holes. I never realized that pot metal weighed that much....those posts are fairly heavy. So if I use the galvanized studs maybe I'll just go ahead and get galvanized nuts and washers to match.
Thanks, Doug
Old Jan 14, 2012 | 09:44 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Thanks, Doug
Which is why the tabs on original posts are so prone to breakage...
Old Jan 14, 2012 | 11:28 PM
Fawndeuce's Avatar
Fawndeuce
Absolutely, also as the convertible top vinyl ages it shrinks, placing more and more stress on the posts each time you latch the top.
Paul
Old Jan 15, 2012 | 07:34 AM
Virginia Vettes's Avatar
0Virginia Vettes
Former Vendor
Look at the postings on the forum for tab repair and you will see a 5/16" set screw that is screwed in with an allen wrench. It is strong ,easy to assemble and looks professional in the installiation.
Just my opinion
To 59 Windshield Post Stud Metalurgy Question
