Clutch / Trans install question
Old Jan 19, 2012 | 07:54 PM
BrettG's Avatar
BrettG
Default Clutch / Trans install question
Finally installing the engine for the second time, will mate the trans up tomorrow. (first timer)
Do I need to grease the inside diameter of the throwout bearing?
Old Jan 19, 2012 | 08:21 PM
DansYellow66's Avatar
DansYellow66
There should be a grove inside the throw out bearing that is to be filled with grease flush to the barrel and a very light coat on inside of the barrel itself. But don't get too sloppy with it.
