PAINT CODE #s
Old Jan 30, 2012 | 08:39 PM
oldvet's Avatar
oldvet
Default PAINT CODE #s
Thanks for your help. I went to the paint store PPG to get the paint to paint my 1960 Corvette go kart. Their computer lists two reds for 1960 for all GM cars. They said if I can get the trim #s they should be able to mix Roman Red and Ermine White. If you have a car with thse colors, would you check your trim tag and give me the numbers? THANKS!!!!
Old Jan 30, 2012 | 09:00 PM
UberLegend's Avatar
UberLegend
Don't think there is a trim tag.
http://www.corvettepaintcodes.com/
Old Jan 30, 2012 | 10:06 PM
5thvet's Avatar
5thvet
No trim tag prior to 63 but they did put the color usually with green crayon on 60's in the trunk on the right vertical panel behind the trunk. The GM code would have been 506A but the PPG referenced above is probably what they want.
Don
Old Jan 31, 2012 | 09:26 AM
Dave Tracy's Avatar
Dave Tracy
Ermine white is 936. The PPG color is 8259
To PAINT CODE #s
