pulling engine question
Old Jan 31, 2012 | 04:30 PM
GEM '62's Avatar
GEM '62
Default pulling engine question
When pulling the engine and transmission as a unit in a 62, do you have to remove the shift from the transmission or will the transmission drop down enough in the back to allow the shift to clear the tunnel?
Old Jan 31, 2012 | 04:42 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
you will to remove the shifter if it is a stock type. if you have a Hurst with the removable stick, then maybe not.
Bill
Old Jan 31, 2012 | 05:08 PM
GEM '62's Avatar
GEM '62
It's a stock shifter, PIA to get to the bolts.
Old Jan 31, 2012 | 05:16 PM
1snake's Avatar
1snake
Remove the cross member first and it's easy to get to them. I just did it last week.
Jim
To pulling engine question
