64 corvette coupe?
Old Feb 3, 2012 | 10:03 AM
ddrr713's Avatar
ddrr713
Default 64 corvette coupe?
I was wanting to know if side pipes will fit on a 64 coupe with out any problems. I know they were not stand for that year. If so were would I buy them for a reasonable cost with the deep sound for an L 76 engine.
Old Feb 3, 2012 | 10:17 AM
62Jeff's Avatar
62Jeff
No problems at all.
Minor mods required to the body behind the rocker panels.
Old Feb 3, 2012 | 10:18 AM
oldsarge's Avatar
oldsarge
Yes they will fit a 64. You can buy them from most of the suppliers. Just do your research and find the best price.
Old Feb 3, 2012 | 10:26 AM
ddrr713's Avatar
ddrr713
Default 64 cpe
Thanks for the reply. I will look around.
Old Feb 3, 2012 | 10:47 AM
Lou64's Avatar
Lou64
Also keep in mind that you can get metal or fiberglass covers for the pipes. The fiberglass ones are more like the original and do not conduct heat that causes those nasty leg burns when you step out of the car wearing shorts.
Old Feb 3, 2012 | 10:48 AM
62Jeff's Avatar
62Jeff
From the 1965 assembly manual:
Old Feb 3, 2012 | 11:14 AM
stingrayl76's Avatar
stingrayl76
A 64 frame does not have the "key hole" slot in the frame that is used to mount the rear of the sidepipe so you will have to tack weld a stud on the frame to mount the rear.
Old Feb 3, 2012 | 01:30 PM
rene-paul's Avatar
rene-paul
The installation is also in my copy of the 64 AIM section n-14 sheet 2.00 thru 4.00. The 65 AIM posted by Jeff has much more detail.
Brgds,
Rene
To 64 corvette coupe?
