Best wiper blades for a 62
Just wonder who make the best replacement wiper blade for a 62? I've owned the car since 03 and thought I'd change them.
It doesn't have to be NCRS.
actually the OE brand fits best, 'Trico ....bad news about them is no more Trico made...The Vette parts stores do have them but way over priced...Watch them, as there are thieves that like them too.....
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
Trico is still manufacturing wiper blades in Brownsville,TX. I called them and they gave me the part number which I can't find. They are sold thru Auto Zone or O'Riely's. See pics of the ones for my 62. They don't match the originals but otherwise work okay. You can call them at
(888)691-5059 Trico Technologies or (956)544-2722 Trico Products. They can point you in the right direction.
John F
John F
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
You could always go to an auto supplier and get the same style refill, and cut the rubbers down to fit your old retainers. Cheap and easy.
Anyway Rain-X is your friend...the early wiper systems ranged from laughable to dangerous even on their best days.
Thanks for all the input. I do use Rain-X in my windshield washer in all my cars and it sure helps at highway speeds.
I ordered a set of Trico off ebay.
Hopefully I don't get caught in the rain this year.
Err...not to confuse matters but Tom Maxwell....the number one restorer of antique washer systems (he rebuilt the one in my '61) is emphatic about running only distilled water in these old TriCo systems. No additives, anti-freeze, bug remover, etc -- ONLY water.
Rain X does make a window treatment you apply externally to the glass with a cloth which is what I use...
I installed a cheap elctric after market washer system.
You can see the plastic reservoir just to the right ,under the master cylinder.
But I will pass the information on to some friend that have C-1s
Thanks,
Rich
Frozen, expanding water could certainly crack the internal plastic components...my car is garaged in Orlando all year so no problem for me. Frankly, I would drain it in the winter if there was a chance of freezing rather than try to run anti-freeze or something in it. The whole system is delicate and hard to repair which is why only one guy (apparently) fixes them.. I was just reciting Tom Maxwell's rules for these vintage systems:
1) Nothing but distilled water in the system
2) To wash, depress and hold the button for 3 seconds
3) Allow 15 seconds between repeated washings
I even wrote them down as he told me so I wouldn't forget !
My vette guy installed a separate electric water pump with a hidden switch, but I'll probably install an electric wiper system if anything ever happens to the original system. I'd love to see one of the original systems working though! It's a shame that there aren't many guys that repair them.
Yeah, draining it would be the smart route. Apparently somebody forgot whoops.
Come to think of it though, although electric, the wiper system would also fit comfortably into the Mr. Goldberg category.
As a number four on Franks' list, Tom recommends to operate the washer system at least once a month to keep everything working.
I know that on mine if I forget and let it go a few months, it takes several shots to get the system primed and working again.
Paul
Just got the wipers in the mail,I got the ones that John suggested.
The old wipers laying in the pack
The new wipers on.
I guess it was a good thing I changed them.I found out my nozzles were out of alignment,one was shooting over the roof. Also the wiper switch wasn't working.I had recently lowered the hood scoop,(it was rubbing on the underside of the hood) and the underside of the hood scoop was dragging on the switch and it wouldn't move enough.I ground a little of the scoop now everything is fine.
The new wipers on.
They are archaic.
Does the Rainex windshield treatment help?
Are there oter brands?
Rain X most definitely helps...the water sort of 'sheets' off the windshield in the rain and visibility is much better. Even at the their tip-top, best condition the C1 wipers are marginal. They are adequate in light rain but quickly 'lose it' in any heavy downpour - don't ask me how I know !
St. Jude Donor '07
yes, although you have to buff it off well when finished applying as it can leave a smear on the windshield that will be distracting looking into the sun. works great though, i have only used my wipers a half dozen times in the last 30 years (and i do drive in the rain...).
cheap enough try it.
Bill
Bill
