Ignition switch replacement
Old May 14, 2002 | 04:52 PM
Crazyhorse's Avatar
Crazyhorse
Default Ignition switch replacement
Can this be done without the key ? I picked up a used cluster and the
switch is still in it. Am I going to have to start cutting on this switch ?
Old May 14, 2002 | 05:14 PM
MasterDave's Avatar
MasterDave
Moderator
Default Re: Ignition switch replacement (Crazyhorse)
You need a paper clip. Straighten it out and push it into the little hole on the bottom of the switch just below the key. This will unlock the center piece (where the key goes). Pull it out. Then you unscrew the outer ring on the gauge side. This allows you to drop the inside piece out. You could have a key made to fit it also. Most any home/automotive locksmith can do it. I did it on mine and the cost was under $20. :cheers:
Old May 14, 2002 | 06:16 PM
58Mike's Avatar
58Mike
Default Re: Ignition switch replacement (MasterDave)
I think you have to have the key inserted for the paperclip method to work.
Old May 14, 2002 | 06:35 PM
67435animal's Avatar
67435animal
You definitely need a key for the paperclip method to work. Get a locksmith to make a key.
Old May 14, 2002 | 09:52 PM
mvette66's Avatar
mvette66
Default Re: Ignition switch replacement (67435animal)
you should be able to pop the chrome cover off the lock face.. with that off you will be able to remove the nut and the assy. It worked for me.
Mike
Old May 15, 2002 | 08:07 AM
Kid_Again's Avatar
Kid_Again
...you didn't say if you want to keep the switch but if it's expendable, you don't need a locksmith to get it out...you need a big freakin' drill bit just large enough to cause the tumblers to drop and release the mechanism - scary but practical (and you won't need a paper clip, fer sure)
btdt
Old May 15, 2002 | 09:00 AM
Crazyhorse's Avatar
Crazyhorse
Default Re: Ignition switch replacement (Kid_Again)
[QUOTE...you need a big freakin' drill bit just large enough to cause the tumblers to drop and release the mechanism [/QUOTE]
Good idea ! Thanks everyone ! :cheers:
To Ignition switch replacement
